  • Guests: 43
mini SGTC power supply sugestions
HvHaxor05
Sat Jan 19 2008, 01:17AM Print
HvHaxor05 Registered Member #1116 Joined: Tue Nov 13 2007, 02:11AM
hay im making a super mini sgtc it will be wound 2" on a 2/3" peace of pvc with 32g wire i want to know what should i use as a power supply i want to make it as small as i can
EE2K11
Sat Jan 19 2008, 04:35AM
EE2K11 Registered Member #1218 Joined: Tue Jan 08 2008, 02:13AM
What about a small rectified CCFL driver? They usually output about 3kV at 5mA or so.
HvHaxor05
Sat Jan 19 2008, 07:02AM
yes that could work ill se what i can dig up
any other ways people can think of
flannelhead
Sat Jan 19 2008, 10:53AM
Or you can use my method with disposable camera inverters and Cockroft-Walton multiplier cascade!
Link2 smile
Sat Jan 19 2008, 04:31PM
I got half-decent results by making a small flyback transformer out of an ATX transformer. Being my first Tesla coil I don't think I did a good job of tuning, so the streamer length could probably be improved. The transformer itself worked well however, and was quite easy to make. About 200 secondary turns, 8 primary turns and some HV diodes were all it took. Link2
HvHaxor05
Sat Jan 19 2008, 06:55PM
i have messed around with camera transformers and i will try to make a 555 driven one my friend made one with a single transistor and 3v input and gotten 1.2kv out witch is atleast to me impressed and yes i have noticed your atx transformer work and am impressed
