  • Guests: 68
SGTC doubts!!!!
Alexandre
Tue Jan 15 2008, 02:11AM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Hi, i a building a mini Tesla Coil, and i bought a NST (8kV @ 30 mA), and i wanted what the values of capacitors my NST can charge, and values that it is not recommended to use.
Thank you.
J. Aaron Holmes
Tue Jan 15 2008, 03:43AM
Alexandre
Tue Jan 15 2008, 03:59AM
I only know that something of the value of the resonant cap, I use less or more of that value?
Bjørn
Tue Jan 15 2008, 04:15AM
There are hundreds of threads you will find useful and there is information in the wiki too. If you spend some time searching I am sure you will find a lot of helpful information.
Marko
Tue Jan 15 2008, 02:02PM
I think this is all you need.. everyone uses these caps for their MMC's and I would strongly recommend you to do so.
There's no 8kV transformer but I don't think you'd be any wrong picking a cap value for a 9kV 30mA.
There are usually few configurations involving larger number of caps giving less RMS current and voltage per cap but at increased cost. For that small transformer I think using one string of 9 or 10 caps would be OK.
Alexandre
Tue Jan 15 2008, 04:13PM
ok
I will see what I can do
thanks
Ultra7
Tue Jan 15 2008, 07:20PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
http://www.teslamap.com/
Try Tesla map.
I would like to just say that you should probably read every thread, book, or web page you can get your hands on before you start building the coil tho.
I know that most people can barely wait to get their sparks on, but read, read, read.
Chances are it will save you money, time, and maybe even your life. cheesey
Alexandre
Tue Jan 15 2008, 08:54PM
I made a coil great Link2
But I tried to make some minor plates with glass, but the NST burned, and wanted to find out why.
