  • Guests: 31
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
10/17 Madgyver (40)
A part of me just died...
skmetal7
Sat Feb 11 2006, 11:20PM
skmetal7 Registered Member #101 Joined: Thu Feb 09 2006, 08:12PM
well my dad is going to take it into Sears repair center and see if they can do anyting with it
Omicron
Thu Feb 16 2006, 01:52AM
im sure it was a fairly expensive one. it has auto ranging, freq, cap tester, continuity/diode tester, 20 amp current meter, bar graph, temp. all the bells and whistles.
Wow... thats a lot better than my $ 10 analog meter
Wow...
skmetal7
Thu Feb 16 2006, 11:15AM
well they couldn't fix it so i guess im on the hunt for a new one. i would like to find the same one but it seems they aren't made anymore...
Fri Feb 17 2006, 01:08AM
I have been really happy with my protek 506 meter...
It has 20a trueRMS current (so it is supposed to read correctly with weird waveforms), and can meausre down to .1ua
1kv voltage in, and it can measure down to the .1mv...
resistance to 40M, in down to .1ohm...
cap tester that reads down to 10nf, but is somewhat limited on the high end at 100ufd; but most caps that large are marked...
The inductance reads to 10mh on all scales, but is good to 100h for measuring transformers...
frequency has everything you need from 1hz to 10mhz
it has an internal temp sensor and comes with a k type thermocouple good to 2000F
You can also program it to put out a 5v square wave at 2 4 or 8 khz
diode checker/audible continuity tester
But best of all it has a serial port sou you can use it as a dac! The resolution really sucks (.1 I think) but it ids useful for recording temp or line voltage or power draw etc over long periods of time...
As for your disposable ones, you cant beat the hf ones...
skmetal7
Fri Feb 17 2006, 02:23AM
hmmm... ill look into that one^
yeah and defanatly an el cheapo one too
Wed Feb 22 2006, 01:15PM
Hi all.
I repaired my last "popcorn" meter when it fried, changed out the main chip but had to repair some damaged traces (i was a bit careless during removal)
Seems to work, can't detect any difference between it and my spare (nearly identical) meter.
I'd take a close-up picture of the damage then clean up with acetone and isopropanol, this should reveal the extent of the damage.
-A
FastMHz
Wed Feb 22 2006, 06:28PM
I use a cheap RatShack meter for unknown testing too - it's a great idea. Since you're looking at new meters, I'll recommend the one that I use most: My trusty TPI 440.
brandon3055
Sat Jun 09 2012, 01:24AM
I agree with the two meters idea I have a very expensive meter and a $9 one I've blown the cheapo more times than I can count
Sat Jun 09 2012, 05:35AM
At home I no longer use 'expensive' dmms,
I now rely on a GBP2.99 one and a GBP9.99 one that has an RS232 interface.
I have checked them both against a calibrated dmm at work
and they are both well within specifications.
P.S.
When there is high power rf around (rf amplifiers, Tesla coils etc.)
a simple analogue moving coil meter gives steadier readings than a dmm.
P.P.S.
Even if your cheap dmm has a very high voltage range
do not try to measure above about 500v as some cheap dmm have poor insulation design.
Also, as the above photo's show ... not all 'expensive' dmm have good insulation design.
Dr. Slack
Sat Jun 09 2012, 07:30AM
It's a bit like the joke about snooker or pool players, how do you tell a professional from an amateur player? The amateur chalks his cue *after* the shot.
After I fried my decent Fluke (you just know that the zzzzt noise from its internals is a bad thing), I bought several £5 ones, with the intention of buying another decent one to keep them in calibration. But I took them into work for a quick check, and they are all so within spec that my £100 has stayed in my pocket.
Unfortunately, acquisition of a decent meter is part of the rite of passage from smart school nerd to frankly dangerous young adult. So we all have to go through the second part of that rite, which is losing it in action.
