  • Guests: 30
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Steve W's Mini SSTC
bluemotion
Sat Jan 12 2008, 07:54AM Print
bluemotion Registered Member #1200 Joined: Mon Dec 31 2007, 01:43PM
Finally I got it run off main without blowing up anything. The credits must be given to Steve W, Mates and Kizmo who help me very much during the progress.
I am still using a small secondary recently wound for my MicroSSTC, with 110v input it produce 9cm sparks and sounds like a broken French Horn.
Primary: 4 turns direct on secondary.
Secondary: Unknown turns, resonates at 6xxkhz
Input voltage: 110v
Here are some photos(a large space behind half bridge is left for the cooling fan)
1200124475 1200 FT0 Dcp 3076
1200124475 1200 FT0 Dcp 3077
]1200124475_1200_FT0_mov00155.wmv[/file]
Mates
Sat Jan 12 2008, 10:30AM
bluemotion wrote ...
I have an experience that winding the primary straight on the secondary gives much worse performance than if you leave a small air gap. I think is it better to use more turns if you want increase the coupling. Air is the best insulator (it has much higher restitance than the PVC, PP, PU isolation). You can check during the the night when the coil is running wheter you see corona froming (blue light) close the the contact of those two windings. In case you see it than it is not good...
bluemotion
Sat Jan 12 2008, 10:47AM
Mates wrote ...
OK. I'll do that.
As for the corona discharge, I see that on the wire connected to the discharge terminal even it has been covered by much layers of PVC tape. I am trying to spray some epoxy on them to see if it will do better than tape.
P.S: My parents start to complain about the noisy discharges cheesey
Zum Beispiel
Sat Jan 12 2008, 12:24PM
Looking good!
Now you just need more power... Are you running full wave or half wave rectified input? Half wave will give longer sparks. Also, try putting a small topload there, that should help too.
Also, use some form of insulation between the primary and secondary... I tried winding the primary on the secondary for my Mark II coil and suffered some serious insulation breakdown there. I was probably a bit out of tune, so that might have also played a part in it.
Happy coiling!
bluemotion
Sat Jan 12 2008, 01:17PM
Zb wrote ...
Looking good!
I am running full wave, maybe one day I'll try half wave 220v
The only problem I didn't receive my new scope.(Weird, the supplier says they did send it.)
So I don't really know how my waveform looks like.
However, it seems works fine when running full wave 110v.
Well, I add a stainless steel sphere, now the sparks reach 14cm amazed
1200143874 1200 FT37300 Dsc00189
