  • Guests: 21
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Induction heater, vacuum tube oscillator.
1 2 3 4  last
Tonskulus
Thu Jan 10 2008, 09:43PM Print
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
This one is my latest project so far. It is basic tube oscillator using inductive grid coupling/feedback.
Commonly used in commerical tubetype RF induction heaters. Tank circuit is insulated from plate voltage by DC blocking capacitor. Output power is 1kW max. I have made lots of research for this project, its not so easy than it looks like. Anyway, it is now working just fine and is very reliable.
And now, some photos and videos:
front panel:
http://www.elisanet.fi/tonskulus/ih/tubeih4.jpg
psu:
http://www.elisanet.fi/tonskulus/ih/ih_psu2.jpg
oscillator:
http://www.elisanet.fi/tonskulus/ih/ih_osc.jpg
heated coin:
http://www.elisanet.fi/tonskulus/ih/ih_coin2.jpg
vids:
http://www.elisanet.fi/tonskulus/ih/getterflash.wmv
http://www.elisanet.fi/tonskulus/ih/tubeih_2.wmv
http://www.elisanet.fi/tonskulus/ih/vtih_3.wmv
Things getting really hot:
http://www.youtube.com/watch?v=aGZRaJhpXsQ
Oh, the resonant frequency, it is approx. 600kHz.
More to come soon!
Thu Jan 10 2008, 10:15PM
Now that's one hell of a first post, it looks great. I like the front panel, it has a nice vintage look.
ShawnLG
Fri Jan 11 2008, 07:38AM
What kind of tubes are you running?
Coronafix
Fri Jan 11 2008, 09:26AM
That is way nice!!
What are you using it for?
You obviously didn't spend all this time making it just because you can!
Did you?
Fri Jan 11 2008, 01:01PM
I like it smile How much current does it draw from the wall socket?
Experimentonomen
Fri Jan 11 2008, 01:12PM
One MOT, do the math :P ;)
Tonskulus
Fri Jan 11 2008, 03:32PM
Ok, tubes are 4-250A tetrodes. I think input power is about 1500-2000Watts but i havent measured it.
Well mostly I just made this for fun and for experience but indeed, there are many useful applications for this like induction soldering, brazing of small parts and im going to make small curcible for melting some metals like aluminium for casting. I like to construct things out of metal so induction heater is very useful tool..:)
Now its time to build impedance matching network(aircore transformer, 12 turn primarycoil and 1 turn secondary out of copper sheet surrounding primarycoil) so that singleturn workcoils can be used. Watercooling is also required for workcoils as there might be over 500Amps of RF current.
Tonskulus
Sat Jan 12 2008, 02:48PM
I made some modifications. Bigger powersupply and bigger tank capacitor and some fin tuning for tankcircuit and now there is parallel feeded workcoil. There is new video in my first post to be seen :)
Marko
Mon Jan 14 2008, 01:37PM
I think you should make some sort of crucible and try melting some steel. (If you haven't yet).
I'd be expecting a lot more than 500amps for a single turn coil :O, you better use some really thick pipe and water cooling - I don't know if that is going to be more practical than a multi turn coil.
Keep the great work up suprised
Tonskulus
Tue Jan 15 2008, 02:34PM
For some complex shaped workpieces, its more easy using just singleturn coils. like, sawtooth hardening work or so. And yes, im going to build watercooling system. Even without matching transformer, workcoil glows orange and tank coil gets really hot in a minute.
1 2 3 4  last
