  • Guests: 54
Problem with Steve's Mini SSTC
bluemotion
Thu Jan 10 2008, 07:02AM Print
bluemotion Registered Member #1200 Joined: Mon Dec 31 2007, 01:43PM
I finally build the Mini SSTC. first, I try to input 50Vdc to the halfbridge(IRFP264*2 38A peak current) and it starts to oscillate successfully. I think that means my bridge is switching the power properly. I try to input 110Vdc and result in the death of my rectifier and FETs(all pin shorted together without any visible damage). It may caused by the over current since my rectifier is only rated at 8A. But I still want to listen you guys opinions.
I did have some 25A rectifiers, I just never thought the primary will draw so much currents so I didn't use them.
Well, another question: What will happened if I input the power to bridge without any load and driving signal(I never did this, just out of curiosity)
Here is the photo of my entire driver
1199948515 1200 FT0 Dcp 3067
Kizmo
Thu Jan 10 2008, 11:26AM
Did you get any sparks with 50V input? Do you have break out point on top load? How many turns you have in primary?
Mates
Thu Jan 10 2008, 11:46AM
It seems to me that the rectifier died after the FETS, because 8A means at least 50A in pulse mode. But next rather use your 25A bridge...The break out point is a good hint; make it sharp and at least 3cm long. I also recommend you to use TVS for protecting the transistors.
BTW: when you used 50V did you checked the performance using a fluorescent lamp placed close to the top load? If not, than this the way how to set your coil (frequency, number of primary turns...)
I just checked the picture you posted - it looks like your transistors have no heat sinks - no wonder you destroyed them cheesey
Don't give it up wink
Mates
bluemotion
Thu Jan 10 2008, 12:19PM
Thanks for you guys' reply.
Well, I did use a sharp breakout point almost 15cm long and when operating at 50vdc there are near 4.5cm discharges without interrupter and the FETs are only a little warm after 1min.
My primary is 5 turns direct on secondary.(When operating at 50vdc, it draw 4.xA from the power supply)
I was using a small secondary which resonates at 6xxkhz.(The new resonator is still under varnishing cheesey )
As for the heat sink, I removed them with the dead FETs.
Also, I am still wondering what will happened if I input the power to half bridge without any load and driving signals. cheesey
Photo of secondary is attached.
1199967525 1200 FT37223 Dcp 3068
Thu Jan 10 2008, 07:04PM
Shouldnt do any harm as long as the GDT is in place to keep the gate voltage down to 0V. There will be some transient current to charge up whatever capacitors you have across the power supply, but the MOSFETs shouldnt draw any power.
