  • Guests: 60
IXYS Gate Driver Weirdness
Josh Johnson
Wed Jan 09 2008, 03:21AM Print
Josh Johnson Registered Member #793 Joined: Sun May 20 2007, 06:50PM
I was looking into a gate driver with a little more oomph than the UCCs I am used to. One thing on the IXYS gate drivers has me a bit worried: http://ixdev.ixys.com/DataSheet/99061.pdf
When disabling these drivers (enable = 0) the output goes to a high impedance state, the UCCs force the output to zero. The last thing I want from a gate driver in DRSSTC use is for it to set the gate floating instead of solidly turning off like I want it to.
I could see putting in an extra transistor to pull the output low on a low enable signal but this seems like a pain I didn't have to worry about with the UCCs. mistrust
Any thoughts on this?
HDR
Wed Jan 09 2008, 04:39AM
HDR Registered Member #1165 Joined: Sun Dec 09 2007, 04:41AM
Have you looked into the UC3710T ? I found it browsing on TI.com for a free gate driver, puts out 6A and works pretty well up to 500KHz (reaching limit of TL494 or my oscilloscope, don't know which) in my coil. I don't think I've seen anyone else use it..
The functional diagram on that chip shows a transistor to pull the output to ground though. Maybe it only goes high impedance when the enable pin is grounded, but operates normally otherwise?
teravolt
Wed Jan 09 2008, 05:29AM
I use thease IC's and just tie the enable pin to vcc
Wed Jan 09 2008, 07:27AM
Just do an "enable" with an AND or NAND circuit so that you force the output low during the "disabled" time.
Indeed you should have been very weary about having a high impedance output to the GDT!
Wed Jan 09 2008, 12:11PM
Josh Johnson wrote ...
A 14A driver over the existing 9A driver is not much of an improvement to justifying going to a new chip / package. If you want some extra oomph without having to worry about the enable functionality of the IXYS driver, then just parallel (2) UCC drivers.
Dan
Josh Johnson
Wed Jan 09 2008, 05:17PM
That is a simple solution. I wanted an enable and was stuck on using the pin on the chip called enable. Sometimes you overlook the easy answer.
Good point Dan. There was a few other thing that I liked about the IXYS driver though.
One, you can get it in the TO-220-5 package which allows for better heat dissapation, alought this most likely isn't a issue in DRSSTC use unless something is going wrong.
Two, the part allows for much higher drive voltages, up to 35V, so I could use a 1:1:1 GDT for a better gate drive signal than a 1:2:2. Maybe this isn't a big deal, however, just something I've read and never tried for myself.
Three, I could subsitiue the 14A TO-220-5 for the 30A TO-220-5 http://ixdev.ixys.com/DataSheet/99045.pdf if I got really power hungry. Although if I needed 30A gate drivers I'd probably be looking into isolated power supplies to directly drive the gates without a GDT.
So after this little debate with myself I think I'll stick to UCCs and parallel if I need too.
