  • Guests: 62
Suggestions For High-Power 555/MOSFET FB Driver
EE2K11
Tue Jan 08 2008, 04:54AM Print
EE2K11 Registered Member #1218 Joined: Tue Jan 08 2008, 02:13AM
I'm new to this forum, so please allow me to introduce myself:
I'm a Freshman EE major at Texas A&M University with a lifelong background of electronics. In seventh grade I began experimenting with High Voltage stuff. I believe it was Sam Barros' PowerLabs website that sparked this interest.
I just built a low-power flyback driver using the simple 555-based circuit. Attached is a picture of the unit. It runs nicely, drawing only 180 mA unloaded and 2 A when arcing. It is in its final stage except for swapping its IRF730 with an IRF540. After this modification is made, I'd expect about 18 kV out with 12 VDC in.
Now, I would like to take this circuit to the next level. I would like to keep the basic design the same except for:
Larger filter cap (4700 µF instead of 470 µF, at least 35 V)
MC7812 12 V 1A voltage regulator driving the 555 (*WHY do these get so hot? I blew two of them with only 20 VDC in driving a 555)
STW18NB40 High Power Mosfet 400V 18.4A instead of IRF540 (larger TO-247 for better heat dissipation on heatsink approx 2x the size)
Second 10K potentiometer for adjusting duty cycle.
Does this all check out? If all goes well, I'd like to be able to get around 30-50 kV out of this new circuit at 24 V input using a standard DC Flyback.
1199767910 1218 FT0 Img 1485
Tue Jan 08 2008, 07:38AM
See my post here Link2 up to 100kV and 150+W is possible from a DC flyback with single MOSFET
EE2K11
Tue Jan 08 2008, 04:22PM
Can I still use your method if I'm only using a 555 and no other ICs? Another thing - are these "fast diodes" easy to find?
Tue Jan 08 2008, 04:38PM
EE2K11 wrote ...
Yes you can use a 555. Fast diodes are pretty common such as UF4007
EE2K11
Thu Jan 10 2008, 01:48AM
A simple question - will the STW18NB40 require a "totem pole" NPN/PNP transistor pair between it and the 555 or will it just be a straight swap? (There is a 100Ω resistor between the 555 output and the MOSFET gate pin)
EE2K11
Tue Jan 15 2008, 02:55AM
OK to mount MOSFET and 7812 regulator on the same heatsink?
Tue Jan 15 2008, 04:54AM
You should be fine, just make sure that you use isolator tabs between the mosfets and the heatsink (the tab on a regulator is usually ground where on the mosfets it is connected to v+)
