  • Guests: 56
skori 24V sstc
Experimentonomen
Sun Jan 06 2008, 06:01PM Print
I just finished putting together asimplified version of the skori 24V sstc cir, and guess what ?
It Worked!! Mine uses a larger secondary so fres is lower and may be why my sparks is only small.
Heres my setup: Link2
Firnagzen
Mon Jan 07 2008, 05:42AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
Oh, the horror of the mess!
Seriously. Neaten it up, it'll make life easier and less prone to disastrous failures caused by shorting.
Mon Jan 07 2008, 05:52AM
Or at least put some solder on the connections amazed
Do you have any pics of the output?
Coronafix
Mon Jan 07 2008, 12:34PM
How come you used so many turns on the primary? The Skori only used one on each Fet.
Where are the resonant C4 & L4? How did you determine the correct quantities for these?
Experimentonomen
Mon Jan 07 2008, 05:51PM
This was just some experimentally testing, for the real deal i´ll be using IRF3205 and try to get it done on a board, now that i know it works.
