  • Guests: 36
  • Members: 1
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
First SSTC completed
bluemotion
Sat Jan 05 2008, 05:00AM Print
bluemotion Registered Member #1200 Joined: Mon Dec 31 2007, 01:43PM
Well, my original intend was to copy Steve's Mini SSTC. However, my scope just dead for unknown reason yesterday. Before my new scope arrive next week, I decided to play with other design instead of just waiting.
After checking what parts I have in stock, I decide to copy Steve's Micro SSTC. I fact, the driver is nearly the same as Steve's Class-E so after my new scope arrived I can quickly turn it into a Class-E SSTC.
It costs me nearly 3 hours to build the driver(Secondary taken from my old SGTC cheesey ) Although I am using the interrupter, the spark is only 1.5cm in length(this makes me doubt that if the interrupter is working correctly.). IFRP460 is only a little warm after running for 1 minutes without heatsink.
Update: Well, i found the problem. My interrupter is NOT working at all. The 555 is dead. angry I should have tested it....Now the steamers reach nearly 4cm and the FET is as cold as the ice. I will post some new pics later.
1199507729 1200 FT0 Dsc00128
1199507729 1200 FT0 Dsc00125
1199507729 1200 FT0 Dsc00129
Properly working pic
1199535336 1200 FT14 Dsc00136
flannelhead
Thu Jan 17 2008, 01:34PM
How much turns does your secondary have? And how much voltage do you have on primary?
bluemotion
Fri Jan 18 2008, 12:59AM
I have wound a new secondary for both my MicroSSTC and MiniSSTC
. Around 850turns with a sphere(4") as topload.
I don't know the exact resonant frequency, but I guess it drop to 5xx khz or so when topload is used.
As for the voltage into primary, it's around 30Vdc.
I know you are trying to power it with 9Vdc. Chances are that you will not get any breakout but light some fluorescent tubes. With interruptor, I can get 4~5 cm breakout. However the fet does hot quickly.
