  • Guests: 45
Problems with Self Ressoant Tesla Coil
MRacerxdl
Fri Jan 04 2008, 06:48PM Print
Hi all, I am new at SSTC's, I was made SGTC's earlier, but now I going to Eletronic Ones :D
Ok, after half year studying Steve's SSTC and I resolv to make one for me.
First I have make the Micro SSTC (That has one Mosfet) Its worked good (like the original project)
Today I started my work at a Half Bridge Tesla Coil, but Self Ressoant too.
I have made that schematics:
http://www.wate.com.br/tesla/EnergyLabs/040108/esquema.jpg
Ok, first I put in a +48V@3A Supply, it work, but only if my hand on the Antenna (Its strange, but it works), I get 1cm sparks at a wire topload. ( http://www.wate.com.br/tesla/EnergyLabs/030108/1/DSC01466.JPG
The 48V Supply its a 3A Transformer with Full Bridge Retification, and 500uF Capacitor. The IRFP460 get hot.
Ok, I decided to put on My variac, I get two 1N4007 Diodes in parallel, and made a Half Bridge Retification without capacitor. I put the variac on 48V position, and turned on the driver circuit. Ok all working same size sparks, but now I get a 60 hertz noise (because the Half Bridge Retification) and the IFRP460 are cold, it doesnt get warm (good thing).
I turn the variac for more voltagem, the sparks get bigger. When the voltage gets at 85V I get bigger spark, some like 3-4cm ( http://www.wate.com.br/tesla/EnergyLabs/040108/DSC01488.JPG)
I have 3 questions here:
1º) After some time ( 30 seconds ) I get a louder sound (like if I put my 110V AC at short circuit) and one of My IRFP460 Died (The second, that makes the short of Capacitor and Tesla Coil Primary). That Happened two times. The other IRFP460 is intact. Why it does make that?
2º) Why I need to put my hand at antenna? The wire is longer and its about 20cm of the top of coil.
3º) What can I make to get my sparks bigger?
Thanks
Fri Jan 04 2008, 07:57PM
Try Steve's "Mini SSTC", it's very popular for beginners here, for a reason smile It's pretty simple to set up and works well.
MRacerxdl
Fri Jan 04 2008, 08:22PM
I see on the site, but here on Brazil it doesnt existi the UC drivers, its online TC4429 and TC4420 (And the TC4420 its very expensive, I dont know why, its about 8x the price of the TC4429) can I use it?
Fri Jan 04 2008, 09:05PM
Mestre Racerxdl wrote ...
I think you can use the lower current ones, just watch so they don't get too hot.
BTW you can get samples of TCs for free on Microchip's site
Dr. H.
Sat Jan 05 2008, 08:42AM
Why don't you build a descrete driver like the one Steve used in his SSTC 2 - Link2
I have built it and works very well. The only problem is the added delay, but i think that it is not too much.
Cheers Huben smile
