  • Guests: 39
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Small Tesla Coil using disposable camera transformers
1 2 3 4  last
flannelhead
Thu Jan 03 2008, 11:19AM Print
Please note this coil was built just as a proof-of-concept. Even though this might look like a fancy way for a beginner to get started with high voltage electronics, it is not.
Some time ago I finished an interesting project. It's a small tesla coil running out of four AAA batteries. Here some specs:
Power supply:
-3V in
-two camera transformers
-~660V output to CW multiplier
-CW output ~8000V (6 stages)
Primary:
-1nF 2kV polyester pulse cap
-6 turns of 0.5mm wire
-static gap ~1mm
Secondary:
-~380 turns of 0.3mm wire
-height 135mm
-diamerer 45mm
-no topload
This coil gives some nice ~4mm discharges and ~25mm arcs! It can also light neon bulbs, fluorescent tubes and so on... It's amazing that the whole thing draws only about 1.5 amps so at 3 volts it's only 4.5 VA power!
Some pics and video:
1199359166 952 FT0 Full View
Mates
Thu Jan 03 2008, 11:36PM
It almost looks like cheating... smile I would never believe you can get so much from such a litle voltage and power...
BTW: I do not see any inverter feeding the transformers. Is it so small? rolleyes
Capper
Fri Jan 04 2008, 01:18AM
Capper Registered Member #914 Joined: Fri Jul 20 2007, 06:22PM
I need one of those on my desk at work.
CT2
Fri Jan 04 2008, 07:46AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
The inverter is only that small resistor going from pin to pin and a transistor (on the side of the transformer I think).
Logan Kennedy
Sat Jan 12 2008, 04:35AM
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
That's pretty wicked!
What a kludge, but I'm amazed it works...
Show us some arc photos, or record a small movie. I've got to see this thing in operation. :D
J. Aaron Holmes
Sat Jan 12 2008, 04:58AM
Logan Kennedy wrote ...
He included a movie. Look again wink
Cheers,
Aaron, N7OE
Logan Kennedy
Sat Jan 12 2008, 05:07AM
OH I see it now, haha!!
Wow, it works, and it's halfway decent. Big surprise!
EDIT: What kind of drive time do you get from those AA batteries? You should probably get some lithium ions for better performance and current! It would also increase drive time drastically.
flannelhead
Fri Feb 15 2008, 08:42AM
With my 850mAh AAA batteries it runs propably 5min. I have also some nice 2500mAh AA cells, I would've used them but I've currently got no holder for them.
Fri Feb 15 2008, 01:28PM
Do you have some pictures, I can't get the movie to work.
flannelhead
Fri Feb 15 2008, 04:33PM
Here's one frame captured and cropped from the video. Notice that the video was taken in a completely dark room and the camera was propably 1.5cm away from the breakout point. The camera was on ISO 400 setting!! The discharges are about 5 mm long.
1203093224 952 FT36853 Discharge
1 2 3 4  last
