  • Guests: 53
Ion motor rotary spark gap - new idea
flannelhead
Thu Jan 03 2008, 09:17AM Print
Hi!
In the summer I experimented with ion motors. (For those who don't know what's an ion motor look here) I got a silly idea: "Hey, why couldn't an ion motor be used for a rotary spark gap?" So I tested it. I took one strand from a multistrand wire and put it on the spark gap's other end which goes to the cap. I powered up and the strand started rotating. Then I brought the other end of the spark gap next to the rotating wire. Everytime the rotating strand went past the other end the gap fired. So this could be a way to make a rotary spark gap without a separate psu! The only problem is to get it running reliably enough.
I attached a pic I quickly drew with paint. Hopefully that explains more. I will also take some pics and maybe video of the setup.
Ionmotor Sg
1199351762 952 FT0 Ionmotor Sg
Firnagzen
Thu Jan 03 2008, 10:55AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
I tried that once, though not for a tesla coil, just for fun.
Some problems I found:
-Slow, inconsistent speed
-It slows down when the arc strikes(!)
-Slow acceleration, may have to be hand-started (Admittedly mine was based off a big heavy disc with wires sticking out, but oh well.
-You really need some 10s of kV to get a nice speed.
Marko
Thu Jan 03 2008, 12:49PM
Yes, you need much more power and rotor momentum for consistent firing.
I once tried t make a gap using a small brushless fan; while transformer was on it was OK, but as soon as I put it to tank circuit it was just stuck in position vibrating randomly and power arcing.
I don't think it was any kind of interference in the fan since they worked well near the gap and sparks.
I'm not completely sure why this happens. Arc always tends to elongate itself magnetically, which could be significant because current is large, plus there is simply large thermal expansion of the air around the arc which tends to push the lever around.
If it stalled a DC fan I'm pretty sure ion motor is not going to work for anything practical.
Thu Jan 03 2008, 02:23PM
Actually, this wouldn't work well for several reasons.
Firstly, the tank voltage of your standard tesla coil is not high enough to produce sufficient corona to create an ion motor. And also, when you have high current, it will have the tendency to pull the electrodes together, so you'll need lots more force to separate them.
