  • Guests: 44
Commercial Mazzilli Flyback driver
Thu Jan 03 2008, 01:06AM Print
Looks like someone had a run of real PCBs done for Mazzilli's work...
I am also somewhat surprised that they used a ferrite core for the series inductor... Might explain why he has such a huge heatsink !confused He did take the effort to add a separate pin for the gate drive, so it looks like it should be possible to run at considerably higher voltages and use a separate 12v gate supply smile Although I can't make out the p/n on the fets, he might have used something with a lower Rds than the irfp250.
As an aside, robin did pretty obviously copy Mazzilli's design (down to the questionably accurate name...), and no where on the site is his name mentioned....
Thu Jan 03 2008, 11:04AM
Well, that inductor is a ferrite bobbin type with a large air gap. It should be OK.
