  • Guests: 52
Minibrute Construction Thread / FAQs
Austin
Wed Jan 23 2008, 03:54PM
Austin Registered Member #1169 Joined: Wed Dec 12 2007, 09:16AM
Wirenut wrote ...
diodes not fitting through the holes of the PCB board? like CR3 and CR4.
Oh yeah, now that you mention it, I did have this exact problem. I just soldered some "posts" out of some of the scrap clipped leads from already-soldered in components, then soldered the leads of the diodes to the posts.
Thats exactly what I did.
This is great stuff Easternvoltage, I don't know how much feedback you get on your book but I promise if I can figure this out then anyone can. smile
Wed Jan 23 2008, 09:37PM
wrote ...
Thanks! Great to get the feedback. My goal was to provide a complete set of plans to build a DRSSTC from the scratch up so it appears to be working!!!
keegan
Thu Jan 24 2008, 02:58AM
keegan Registered Member #596 Joined: Thu Mar 22 2007, 12:56AM
I'll jump in here with my first post. I just finished building the minibrute as my first tesla coil, it is currently producing 2-3 foot arcs with a 450A limit.
I am using a top mounted breakout (4" of 1/4-20 threaded rod, ground to a point) mainly to prevent arcs to the primary.
I have a question about the feedback transformers, does it matter if they are between the MMC and the primary coil or between the H bridge and the MMC? Does the MMC offset the phase of the current?
Thank you Dan for your books!
Thu Jan 24 2008, 04:48AM
Review Kirchoff's current law, there *cant* be a phase shift in the current of a series circuit. It does in fact matter because the node connecting L to C has many kV on it. Review ohms law, V = I*Z where I is 450A and Z is the impedance of your MMC or primary at your operating frequency.
Final answer, put the CTs on the output of the H-bridge, not between the MMC and primary because there is HV present there, and you certainly wouldnt want a fault between the primary circuit and the CT!
Austin
Thu Jan 24 2008, 04:59AM
I was looking through the schematic and was wondering if C86 was on the Resonat Driver Board? It's in the schematic but it's not on the board that I can find. Another C32?
I also had another question, I couldn't find C7, C8, C62, C64, C66, C68, C81, C83 labeled on the circuit board. My friend had an idea that they were just all of the un-labeled boxes. Is this correct?
Thanks for the help.
Wirenut
Thu Jan 24 2008, 06:16AM
Wirenut Registered Member #141 Joined: Sat Feb 11 2006, 01:14PM
Looks like you caught another one - as with c32, I did not include this on mine and it works seemingly fine, but EVR will have to comment on its necessity.
Yes.
Welcome Keegan. Any pics?
Bennem
Thu Jan 24 2008, 07:00AM
Wirenut
I see from the layout of your base that
you connected your feedback CT on the HV side of
your MMC.
See Steve Wards post as to why he dosn't reccomend to
place the CT on the HV side.
Just a thought.
Mel.
Wirenut
Thu Jan 24 2008, 08:09AM
Wirenut
I see from your layout of your base that
your MMC.
Yeah, I see how this could lead to a catastrophic failure. I didn't know there was a difference previously. Just out of curiosity, what is the approximate voltage on the primary? I don't know the primary impedance, but Fres is ~160kHz and pri current is ~1000A max.
Austin
Thu Jan 24 2008, 09:26PM
Wirenut wrote ...
Wirenut
your MMC.
-Just so I understand correctly, The placement of the CT should be placed where I drew the arrow in the image below?
http://4hv.org/e107_files/public/1201209653_1169_FT1630_1200725766_141_ft1630_img_0143.jpg
-Does the polarity matter for VR62, VR61, and VR107-VR110 (it says Bi-Directional)
-Are three wires being wrapped around T1?
Ie, Wire#1 is (S1/S2), Wire #2 is (G1/G2), Wire #3 is (twisted pair -> Gate DRV/RTN -> from the resonant board)?
Wirenut
Thu Jan 24 2008, 10:24PM
Yes, that is the recommended spot.
Nope.
Not quite. There are 3 wires, but wire 1 will be s1/g1 and wire 2 will be s2/g2. Wire 3 is correct. I had a hard time finding wire that was small enough to fit 20 turns on the ferrite. What I ended up using was wire from an old parallel cable. I took 2 strands (red and blue in my pic) and twisted them tightly together using a drill. I then wrapped 20 turns on the ferrite. Then I wrapped 10 turns over the top of the red and blue (yellow in my pic) with a third wire. I fed the leads of the 3rd wire through the holes in the board and then twisted them together, holding the ferrite to the board. I could then trim the red/blue wires to the correct length. I'm not sure if it matters, but I put both turn-1-wires to g and both turn-20-wires to s.
