  • Guests: 45
Questions about TL494
MRacerxdl
Sat Dec 22 2007, 03:27PM Print
Hi all, I have found a TL494 in one Backlight LCD Inverter circuit here, its SMD and its working.
I plan to use it, but my question is:
On the datasheet I see 1 to 300kHz frequecy operation, but it works with higher frequencies?
And I can use the DBL494 for that use? (Its like TL494, but its not SMD, its DIP, It can be found on computer power supply)
Thankss
HDR
Sat Dec 22 2007, 03:57PM
HDR Registered Member #1165 Joined: Sun Dec 09 2007, 04:41AM
The DBL494 appears to be identical to the TL494 from the datasheet.
MRacerxdl
Sat Dec 22 2007, 04:29PM
Yes, In specs its identical, but the DBL494 its DIP, and its better for me :P
But the TL494 works with frequency >300kHz?? Or I need a SSTC that have FRes at <300?
Marko
Sat Dec 22 2007, 05:50PM
No, I don't think you'll be able to amke it work a tmuch more than 300kHz. And I think you'll be much better to use feedback instead of open loop control for a SSTC.
Sun Dec 23 2007, 04:20PM
The TL494 comes in DIP too. What package an IC comes in changes little more than size and power dissipation.
