  • Guests: 77
Nice plasma globe - does emit x-rays?
Thu Mar 09 2006, 06:55PM Print
I've made a plasma globe from a big incadescent bulb, and about 30kV@20kHz from AC flyback. It works very nice, producing multiple white-purple-blue streamers inside the bulb.
Picture:
1141929875 152 FT0 Globe3
However, I'm a little worried about it emitting x-rays. The glass 'stick' that held the filament (the filament is no longer there) is hollow and probably with vacuum inside. It glows dark green (it is not obvious from the picture; the camera didn't capture it properly) and continues glowing even after power is removed for about half second. My question is, does it really emit x-rays and if so is it safe to look at it? dead cry
Thu Mar 09 2006, 07:04PM
x-rays are created when high energy electrons are accelerated into a metal target. i doubt you will have anything like that occuring within a plasma globe.
Thu Mar 09 2006, 08:05PM
EastVoltResearch wrote ...
Glad to hear this, so it is safe to look at it for long periods of time?
Also, what then causes the strange green glow? confused It looks dangerous! tongue
Thu Mar 09 2006, 08:16PM
I think it is a fluorescence/ phosporescence phenomenon, not X-ray emission. The glass can contain different ion metals, that are excited by the streamers and can emite light (with a lower frequency, longer wave lenght), after the electric discharge stops.
Thu Mar 09 2006, 09:17PM
Registered Member #256 Joined:
ive had this happen as well, i put a small fridge bulb on my tc and the whole bulp glowed green after turned off! i was sondering bout it it looked cool
i wouldnt say there is any problem with viewing it, just be careful not to peirce the thin glass envelope!
Wolfram
Fri Mar 10 2006, 05:41AM
I think this is what's called nitrogen afterglow. There are more details (and pictures) here: Link2
Anders M.
Dr. Shark
Fri Mar 10 2006, 08:28AM
The experiment described in the link is seriously cool. I wonder if I could put together a Class-E amplifier that would do the trick.
Sat Mar 11 2006, 12:55AM
If you are concerned about x-rays from any experiment you might be able to obtain an X-ray radiation badge. Put it near it for several minutes/hours and send it in to the lab for analysis. They can tell you the roentgen levels it was exposed to leaving no doubt about its safety. This would hold true for anyone doing experiments where they suspect ionizing radiation.
If you are seriously interested, I can inquire at work where these can be obtained/submitted for anaysis.
Sat Mar 11 2006, 01:24AM
I have a really good pic of that green glow that seems to last a little after the power is shut off. There is a refection under the bulb from the HD platter is is sitting in.
1142040281 53 FT3622 Lightbulb
