  • Guests: 42
parallel capacitor troubles
Hrothgar
Wed Dec 19 2007, 09:10PM Print
Hrothgar Registered Member #1180 Joined: Mon Dec 17 2007, 12:26AM
If you look at my avatar you will see my tesla coil blue print, but the problem is my spark gap never reaches breakdown voltage, no matter how close the terminals are, what the devil is going wrong?
(ps. all the connections and stats are right on the money)
Shaun
Wed Dec 19 2007, 09:17PM
I think if all connections and stats were right on the money, it would work. Do you have anything a little more detailed than your avatar (pics, specifics, etc.)? That schematic, with proper components, is fine, but theres obviously something more than that if its not working.
Are you sure you don't have a bad power supply (can you draw arcs form the transformer only, w/out a tesla coil attached)?
A shorted capacitor may cause this as well.
Hrothgar
Wed Dec 19 2007, 11:47PM
no, I figured out that it was a bad connection, but now only one of the capacitors in the circuit is operating, and it gets really hot, the gap makes arcs about a 64th inch long, and the transformer on its own makes about inch long sparks
MOT_man
Thu Dec 20 2007, 01:17AM
What kind of capacitor is this? Mica? Polyfilm? .... curious. Excessive heating usually mean internal arcing.
Hrothgar
Thu Dec 20 2007, 02:14AM
I'm 4 running 10kV 4.5nF ceramic disk capacitors in parallel
Shaun
Thu Dec 20 2007, 03:06AM
Well, If your transformer is STARTING an arc at about an inch, your capacitors don't have near enough voltage rating. If you can pull the arc to 1", thats different. A 1" starting arc means ~25kV.
I would try taking out all the caps, testing them for continuity (or lack of it), and if they passed I would put them in series and try the coil that way. Unless internal arcing hasn't already killed them.
EDIT: plus, ceramic disk caps are known to be pretty bad for TC use.
MOT_man
Thu Dec 20 2007, 08:58AM
ceramic disc capacitors cannot take the rapid discharge and will fail quickly. Very few capacitors are built to withstand such abuses....
However, polyfilm MMC's from CDE - the 942C series of capacitors are super well built. If you have the money these capacitors are very coilers dream :)
Hrothgar
Thu Dec 20 2007, 04:04PM
Thanks, that's a huge help!
