  • Guests: 39
Heatsink ground
KresoLiubov
Tue Dec 18 2007, 06:41AM Print
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
Should heatsinks below primary be grounded?
Tue Dec 18 2007, 02:39PM
Are you referring to the switching devices heatsinks? If so, then it depends on (2) main things:
1. Is the heatsink pad on the component electrically isolated? If not, then you need to either keep the heatsink floating or isolated using a thermal pad etc...
2. Safety (varies depending on design)
KresoLiubov
Tue Dec 18 2007, 04:51PM
EastVoltResearch wrote ...
There is thermal pad between mosfets and heatsink.
Tue Dec 18 2007, 07:54PM
KresoLiubov wrote ...
Then i'd definitely ground them to earth ground.
KresoLiubov
Tue Dec 18 2007, 08:27PM
Thank you verry much smile
