  • Guests: 48
SSTC box heating
Linas
Sun Dec 16 2007, 07:31PM Print
Hi everybody
I making very small (5Kg all sstc) and powerfull (1KW) SSTC, and there is some problem.All the inside of plastic box is covered with aluminium tape and grounded.Unaccountably the box gets warm,though mosfet are quite cold and refrigerating.how primary and secondary is on the box ,the box's heating ,when i take down the primary and secondary off the box,the box's not heating.How to eliminate the heating when the primary and the secondary is on the box? Maybe the induction heating of primairy is guilty
How to eliminate that heating?
CT2
Sun Dec 16 2007, 07:35PM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
Cut stips in the foil, it might stop any currents that are induced. Although there is probably a better option.
Linas
Sun Dec 16 2007, 07:45PM
that how it look
1197834346 1143 FT36069  Mg 0861
Derek_L
Sun Dec 16 2007, 09:21PM
Derek_L Registered Member #1125 Joined: Fri Nov 16 2007, 09:13PM
Mount a some fans on the inside. You can get them in all voltages and sizes.
Linas
Sun Dec 16 2007, 09:26PM
then senundary is not on box, but near,and no heating in box... :S
Linas
Tue Dec 18 2007, 05:09AM
Any ideas ? confused
CT2
Tue Dec 18 2007, 06:07AM
I still think it's kind of like an induction heater, you need to either take the primary coil away from the foil, or cut slits in the foil to stop currents from circulating in it. Someone else may have a better suggestion, but I think that would work. IIRC waverider or blackplasma had a HF coil with a copper ground plane right under the coils, and he cut strips in the copper to stop this.
Tue Dec 18 2007, 02:37PM
I agree. Move the primary from the box. Not good. Even if you did manage to keep it cool from fans, you still have those losses which are probably pretty considerable.
