  • Guests: 73
NE555+IRFP240=SSTC Driver (Would this work?)
flannelhead
Sun Dec 16 2007, 11:58AM Print
Hi!
Some time ago I found this kind of circuit http://uzzors2k.googlepages.com/ET_Flyback_basic.gif/ET_Flyback_basic-full.jpg for driving a flyback. But what if I replace the 1nF cap with a 100pF one, the frequency rises ten times bigger, could it then be used as a simple sstc driver? And will IRFP240 work well in this circuit?
Sun Dec 16 2007, 12:08PM
Do you think that the 555 timer could drive a fet fast enough? In other words it wouldn't work
flannelhead
Sun Dec 16 2007, 12:12PM
In fact the NE555 datasheet says that the chip works at over 500 kHz.
Sun Dec 16 2007, 12:16PM
It could drive it fast enough if it could supply enough current to drive it but this isn't the case. This is why we use a powerful gate drive ic.
flannelhead
Sun Dec 16 2007, 12:20PM
What gate driver do you recommend then?
Sun Dec 16 2007, 12:27PM
I would recommend to build a self tuning coil, I tried the 555 approach when I first started to mess around with sstc's. I found out that the easiest way to build a sstc is by using a self tuning circuit like this one, it's really easy to build.
Sun Dec 16 2007, 01:17PM
I think the NE555 CAN drive smaller (<2nf) fets at SSTC frequencies. However you would need to run the coil in Class E (resonant capacitor from drain to ground) otherwise you would smoke your fet soon. This requies a bit of tuning and you definately need a scope to get it working properly.
flannelhead
Sun Dec 16 2007, 02:21PM
Thanks for replies. I think I will be aiming towards the Steve's Micro SSTC circuit. However, my local electronics supplier doesn't have tc4420 drivers. So which driver should I try?
