  • Guests: 46
Big Coil Driver (or small)
Tom540
Sat Dec 15 2007, 06:17AM Print
Tom540 Banned on 3/17/2009.
Okay, I've been very slowly gathering parts for a BIG Tesla Coil and I was playing around with the Steve Ward style driver and made a few changes to suit my needs.
Of Course it works exactly the same way I just wanted to eliminate a few parts. If anyone sees any problems let me or thinks it might now work for whatever reason let me know. I will probably add an option for an external interrupter for the real version.
Here is the PDF file:
]1197699400_487_FT0_big_coil_driver_rev_a.pdf[/ file]
Sat Dec 15 2007, 07:12PM
1. First you may need to put some 0.1uF caps on the input and output of those 78xx voltage regulators for stability. Check the datasheets. I typically put a 0.1uF on both input and output.
2. You need protection diode from output to input on the 78xx series regulators. When you disconnect power, you have a large output cap which will tend to discharge back through the regulator damaging it. A diode prevents this.
3. I don't like the diodes you are using for D1 and D2. Too slow. Use a fast diode such as a 1N5819 etc...
Tom540
Sat Dec 15 2007, 07:45PM
Ahh, thanks I always forget a few little details like those .1 caps. I'll add that.
Tom540
Sun Dec 16 2007, 12:18AM
Well I made a few mistakes on the one shot but it's fixed now. Everything works. Haven't tried it on an actual coil just yet. A few cap values were wrong as well.
Here is the updated version.
] 1197764205_487_FT35998_big_coil_driver_rev_b.pdf[/ file]
