  • Guests: 48
Tesla Coil on TV in Germany
DrZoidberg
Fri Dec 14 2007, 08:43PM Print
DrZoidberg Registered Member #350 Joined: Mon Mar 27 2006, 05:14PM
Whose TC are they using? Someone from this forum?
Edit:
Here are some pictures
6qc204g
Headshot:
6t4gncn
Reaching
Fri Dec 14 2007, 10:53PM
none of this forum. the tc was build from a team of physics students in a university laboratory near munich. really nice setup which can produce 4 to 5 meters lightning with around 15kW input.
its a rotary spark gap coil powered by a really huge 10kV transformer.. thats all i know about it. they dont have a website or something else,.
Crow187
Sat Dec 15 2007, 06:36AM
Crow187 Registered Member #795 Joined: Mon May 21 2007, 06:04PM
I have seen this coil in Wolfsburg, there I got information...
Höhe gesamt (total height) 4m
Gesamtgewicht (total weight) 770kg
Leistungsaufnahme (power consumption) 15kVA
Eingangsspannung (input voltage) 400V
Primärkapazität (primary cap) 240nF
Sekundärkapazität (sec cap) ca. 0,1nF
Primärspule (primary coil):
Windungsanzahl (windings) 7
Spannung Normalbetrieb (voltage normal operation) 10kV
Maximale Spannung (maximum voltage) 15kV
Sekundärspule (secondary coil):
Windungszahl (windings) ca. 1200
Höhe (height) 2,7m
Innendurchmesser (diameter) 60cm
Gewicht des verwendeten Kupferdrahts (weight of copper wire) 20kg
Länge des Kupferdrahts (length of copper wire) 2km
Durchmesser Kupferdraht (diameter of copper wire) 0,7mm
Resonanzfrequenz (resonance frequency) ca. 33kHz
Spannung Normalbetrieb (voltage normal operation) 1,7MV
maximale Spannung (maximum output voltage) 2.6MV
Durchmesser Torus (diameter toroid) 1,6m
Höhe Torus (height toroid) 40cm
bye, Lukas
DrZoidberg
Sun Dec 16 2007, 03:26PM
Here are 2 videos from the tv show
