  • Guests: 53
Interrupter
KresoLiubov
Wed Dec 12 2007, 12:28PM Print
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
I'm interested which of interrupter circuit you use and which one is considered to be best?
Tom540
Wed Dec 12 2007, 06:06PM
Tom540 Banned on 3/17/2009.
I like the dual NE555 timer (same one Steve Ward uses) version because frequency adjustment doesn't screw with the pulse width like the single timer version does.
Dr. H.
Wed Dec 12 2007, 07:43PM
I fully agree with Tom540. This type of Interrupter gives you freedom. You don't have to worry when you change your frequency that the pulse width will change. While with only one 555 it is possible to overheat and destroy your bridge before you notice what is happening.
KresoLiubov
Wed Dec 12 2007, 08:05PM
Is it this circuit Link2 ? And what is "burst mode" i didnot completly understand it.
Wed Dec 12 2007, 08:25PM
Why did no one mention tl494? It has independently adjustable frequency and duty cycle.
Tom540
Wed Dec 12 2007, 08:59PM
I've never used the tl494. I do have some surface mount ones at home in a drawer.
Shaun
Wed Dec 12 2007, 11:35PM
About Burst mode, I like to think of it as interrupting the interrupter. It basically does exactly that, allowing you to use extremely high BPS or duty cycle for short periods. I left that out on my interrupter, however, in favor of single shot.
Thu Dec 13 2007, 02:20PM
KresoLiubov wrote ...
Actually, you should probably define what "best" means?
- Some are simple (just a few controls)
- Some are advanced (lots of controls)
- Some can accept music source to create audio modulated coil
- Some are smart (fault detection, etc...)
- Some are uP based
etc...
The "best" interrupter design should be based on what your specific application / requirements are.
KresoLiubov
Thu Dec 13 2007, 05:07PM
EastVoltResearch wrote ...
- Some are uP based
etc...
Simple to control on and off time and work reliably. I still use something similiar to Steves Interupter on Mini SSTC but simply wanted to upgrade it
