  • Guests: 72
Corona dope
Hazmatt_(The Underdog)
Thu Mar 09 2006, 05:53AM Print
I've had an enromous depature from my Tesla Coil's performance, its really poor now. I think I found one of the problems, Corona Dope.
The constructed capacitor bank was two parallel plates of FR4 conductive on the outside with the laser caps inside. Well, I had problems with arcovers so I 'doped' the side I had arcs too, then mysteriously, my TC wouldn't perform as well.
Today I wanted to see if I went back to 1.6Cres from the present 2.6Cres, if I could get my performance back, but not even close. I cursed the sparkgap.
Well, wouldn't you know it, the dope seeps really badly! So badly that at the end of the screw there is a light coating of dope. The threads are doped to an extent, and the washer underneath was glued to the bottom of the head!
I have to keep the washer to prevent 'bottoming out' in the caps.
What I strongly recommend. Paint the heads before you put the cap together. Anything else will result in insulated caps.
I am posting this because nobody tells me these things.
Matt
1141883616 135 FT0 Doped
