  • Guests: 37
[moved] tv flyback
rp181
Mon Dec 10 2007, 11:33PM Print
is there any [easy] way to isolate and take away a flyback driver from a full circuit? want to preven buying unneccesary things
Shaun
Tue Dec 11 2007, 03:04AM
If you mean use parts within the TV to build your flyback driver, yes it is possible, although not nearly as good as a 555 or ZVS driver.
You will need to find the Horizontal Output Transistor (HOT). It will be on a large heatsink, probably near the flyback. This can be used in place of the 2n3055 transistor in the single-transistor flyback driver circuit. Don't expect a huge increase in performance, tho.
EDIT: I think this thread is in the wrong forum.
rp181
Tue Dec 11 2007, 03:14AM
oops, ment to put in general, mod can move =)
when you say single transistor driver circuit do you mean this:
Shaun
Tue Dec 11 2007, 03:56AM
Yes that is the driver. If you intend to do this, try not to detach the transistor from its heatsink. Chances are you will need this. The driver will still be very low power, inefficient, unstable, and generally bad, but what the hell, you get what you pay for. In this case, nothing.
Of course, theres nothing wrong with that. I too used this driver for a few months, and now Ive graduated to a powerful ZVS that can pump 600W into a flyback and have the heatsinks only get lukewarm. :)
rp181
Tue Dec 11 2007, 02:24PM
this will actually be my first HV things :) so i just wanna get to draw arcs :)
