  • Guests: 42
Does this look like it would work? (My first SSTC)
1 2 3 4
HDR
Sun Dec 09 2007, 05:42AM Print
HDR Registered Member #1165 Joined: Sun Dec 09 2007, 04:41AM
Sstc01rr1
Mod edit: Does the number 400 mean anything to you? It should. It's the maximum allowed width of an image in pixels.
Its based on the design found here, Link2
I made some changes to the first design to add the safety diodes from the second, but still only use 2 MOSFETs. I also replaced the bunch of transistors with driver ICs, and used the IC's inverting functions instead of a transistor to invert the wave.
Does the design look like it would work if built? I don't want to have to order more parts and pay double shipping if something has to be changed...
Mates
Sun Dec 09 2007, 10:49AM
I'm using the same driving circuit, but I use UCC37322(1) each connected to one of the OUT ports of TL494. Neither of the OUT is connected to the ground (it is not necessary and it destroys the shape of the signal litle bit). I'm also without UF4001, but that's why I could not buy them. It works very good for me...
However, my power part is different. I add the TVS, I'm using IGBT and no series diodes and more other changes...
HDR
Mon Dec 10 2007, 05:20AM
I made a PCB for the circuit.. I'm going to enclose it in the case of a dead power inverter, the MOSFETS are positioned in the same place the inverter's were, so I should be able to use the case as a heatsink, and it has a fan built in. Can someone please cheak over it and tell me if it would blow up as soon as I power it? This is my first solid state tesla..
Expresspcbcc7
The holes labeled L(1) and L(2) are where the connections to the primary go. I haven't gotten a transformer yet, so I don't know the pin spacing to put it on there..
IC1 7812 Voltage Regulator
IC2 TL494 PWM Controller
IC3 UC3710T
IC4 UC3710T
C1 1000uF 35V Electrolytic
C2 1000uF 35V Electrolytic
C3 100nF (104J Green)
C4 82uF 200V Electrolytic
C5 100nF (104J Green)
C6 100nF (104 Blue)
C7 100nF (104 Blue)
C8 220pF (221M Orange)
C9 100nF (104 Blue)
C10 10uF Electrolytic
C11 .1uF Audio In (104 Blue)
C12 470pF
C13 470pF
C14 470pF
C15 470pF
VR1 10K Trimmer Pot
VR2 25K Trimmer Pot
R1 2.2K Ohm
R2 390 Ohm
R3 470 Ohm
D1 HER101
D2 HER101
D3 HER101
D4 HER101
D5 1N5822
D6 1N5822
D7 BZX55C15
D8 BZX55C15
D9 BZX55C15
D10 BZX55C15
D11 FEP16JT
D12 FEP16JT
L1 Toroid Transformer
Tom540
Mon Dec 10 2007, 03:53PM
Tom540 Banned on 3/17/2009.
Maybe just make the collector and drain traces floods instead, or make them a tad thicker. They look okay for an SSTC but It wouldn't hurt to make them fatter.
HDR
Tue Dec 11 2007, 03:51AM
Heres what I hope is the final version of the PCB. I made the traces around the FETs thicker, and added in the transformer and rectifiers. This is viewed from the component side, through the PCB. IC2 is surface mounted on the other side, which is why its backwards.
Expresspcbet1
Updated Part List
The main issue I'm going to have with this is how to drill the small holes... I do not own a drill press and have a very unsteady hand. I'm trying to build this on a very small budget for a science project.
Also, how stable does the power supply have to be? Would hooking the case fan in before the voltage regulator have a negative effect on the circuit?
RickR
Tue Dec 11 2007, 04:21PM
RickR Registered Member #93 Joined: Thu Feb 09 2006, 04:11PM
It looks like the STW20NK50Zs have built-in zener protection. You may be able to skip adding the external zeners on the gates.
Rick
HDR
Tue Dec 11 2007, 09:54PM
I already purchased the zener diodes, so I might as well use them, then I can swap different mosfets in if them burn out, I found some IRF640s on the dead power inverter I'm using parts from..
Edit:
How much current does the 12v transformer have to supply? and is a 16mm OD, 9.6mm ID, 6.35mm thick toroid good for a gate drive transformer?
HDR
Sun Dec 16 2007, 02:52AM
I hope this isn't breaking the double posting rule, since I have new info and more questions...
My parts finally got here, so I want to make sure of a few things before I etch the circuit board..
How much current does the driver circuit need? I have a 500ma transformer, but my LEDs and fan draw around 200, so its really a 300ma supply.
Is the voltage regulator necessary? The 7812 datasheet says the input voltage should be above 14.5V, my transformer only supplies 12.6V; so isn't the regulator just a voltage drop? Wouldn't some additional capacitors remove any voltage spikes?
Is the toroid in my last post good for a gate drive transformer? (16mm OD, 9.6mm ID, 6.35mm H)
Would it be ok to have a switch to switch in/out a DC smoothing capacitor on the HV side? I want to be able to switch from pulsed to smooth DC to adjust the properties of the spark (pulsed for normal operation, smooth for audio)
Sun Dec 16 2007, 05:52PM
That should be just enough, actually. Though, it strongly depends on the frequency and the gate charge of the MOSFETs.
Yes, its a "variably precise" voltage drop, though. With 12.6VAC you will likely end up with about ~17.8VDC after rectification and filtering, you will certainly want the 12V regulator on the ICs.
Dimensions sound pretty small. Its a matter of fitting enough wire on there, usually. I normally go with something in the 25-30mm OD range.
Yes, but i wouldnt do a "live" switch while in operation!
Tonic
Sun Dec 16 2007, 07:16PM
Steve Ward wrote ...
Is there a rule of thumb for choosing transformer for gate driver depending on frequency and peak amper (or charge in nanoculombs)?
