  • Guests: 55
Scantesla compiled for modern computers
Bjørn
Sat Dec 08 2007, 06:12AM Print
I have compiled Scantesla 8.10 with optimizations for modern processors and on my computer it is about 5 times faster than the original and seems to produce the same results. The only changes I did was to comment out some stuff that was specific for old DOS compilers like gotoxy(). It probably needs a Pentium 4 and Windows or something similar to run. If someone could try it out and see if it is a lot faster and working on their computers too it would be helpful.
]1197094330_27_FT0_scanteslamoderncpu.zip[/file]
ragnar
Sat Dec 08 2007, 06:31AM
I'm running XP and it does an illegal operation upon running -- should I set any compatibility modes?
Herr Zapp
Sat Dec 08 2007, 07:04AM
My operating system is XP Professionsl (V5.1.2600) and the recompiled Scantesla won't run (doesn't appear to even start). Curiously, XP won't provide any debug information after attempting to run the program. Processor is 1.6GHz Pentium M in a Dell Inspiron 9200 laptop with 1Gb of RAM.
Shan
Bjørn
Sat Dec 08 2007, 07:41AM
I failed to mention the crucial point that it needs the original Scantelsa 8.10 files to run. It failes for me too when run alone. The original has the same problem so the source could do with a bit of a cleanup. Unzip this archive and drop the new .exe in with the files and try it.
]1197099718_27_FT35619_scantesla810.zip[/file]
Herr Zapp
Sun Dec 09 2007, 03:26AM
Bjorn -
OK, the missing files appear to have been the cause of my problem. After adding them, ScanTesla seems to run fine. Judging only by how quickly the parameters are updated, your recompiled version seems to run about 3X as fast as the original version.
Shan
Bjørn
Wed Dec 12 2007, 03:03PM
That sounds good.
Anyone with a good old Pentium 4 or AMD processor?
Derek_L
Wed Dec 12 2007, 03:26PM
Derek_L Registered Member #1125 Joined: Fri Nov 16 2007, 09:13PM
It ran great on 2 of my P4's 2.0 and 2.4
and on my x2 4200 2.2
Good work Mr Baeverfjord
Tom540
Wed Dec 12 2007, 05:54PM
Tom540 Banned on 3/17/2009.
Now all it needs is an easy to use GUI and to be rid of that annoying .txt file.
