  • Guests: 29
Ben7 (29)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
Tea-pot top loads and X-rays
Mates
Fri Dec 07 2007, 01:22PM Print
I’m using thermo isolating stainless tea-pot as a top load on my coil Link2 and I think I’m not alone. It has the advantages in accessibility (every store with kitchen stuff), the total surface is much bigger than the occupied space and it looks esthetically good.
But, these pots are in fact Devars jars – it means two layers of metal isolated by vacuum. My warning and also a question is whether the vacuum and high voltage cannot produce X-rays in this configuration. I rather made a small hole into my top load to release the vacuum and I recommend the other users to do the same…
Cheers Mates
Tom540
Fri Dec 07 2007, 03:44PM
Tom540 Banned on 3/17/2009.
I don't think it would be a problem since its made of metal. If it was glass then that might be a problem.
Mates
Fri Dec 07 2007, 04:16PM
Tom540 wrote ...
I operate 150KV 15mA X-ray machine at work and it uses 1,5mm thick plates of copper as a filter for removing the low energy photons! The plate of stainless steel the tea-pot is made of cannot stop high energy photons in case they are really produced.
Honestly, I also think it is harmless. However I can not measure it so I'm rather double sure and released the vacuum...
Marko
Fri Dec 07 2007, 04:37PM
Have you guys tried to Google ''Faraday cage''? :p
Mates
Fri Dec 07 2007, 05:33PM
Marko wrote ...
What? Are you replying the right thread?
What has a faraday cage to do with a possible X-ray radiation??? X- rays are photons, only thick layer of high density material can stop them...
Tom540
Fri Dec 07 2007, 06:02PM
I didn't know they were photons but i guess that makes sense. After all when you go and get x rays it creates a picture on the film so i guess it would have to be photons and they also shield you with thick lead and not a piece of foil or something.
Fri Dec 07 2007, 07:30PM
I think what Marko is trying to say is that because the pot will act as a faraday cage, there won't be any potential difference inside the pot, so no x-rays will be produced.
c4r0
Fri Dec 07 2007, 07:31PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Furthermore, I think this vacuum is far too bad for generating x-rays...
Mates
Sat Dec 08 2007, 12:36AM
... wrote ...
That’s interesting with the faraday cage concept… Sorry to Marco I did not get it. But still I do not think there can’t be any difference in potentials on top-load like the tee pot is…. I made a small scheme where I’m showing why I think there could be a difference and why the electrons could go through the vacuum.
1197074004 1025 FT35565 Graphic1
Once the break out starts, there must be temporary charge depletion in the closest vicinity of the break-out point. The question is which way the electrons choose for the flow…
colin heath
Sat Dec 08 2007, 01:30PM
colin heath Registered Member #123 Joined: Fri Feb 10 2006, 12:58PM
i am afraid i have to disagree here.
Stainless Steel is an excellent moderator for xrays. it has to be as most inspection machines used for industry use this material for that reason.
cheers
Colin
