  • Guests: 43
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Demo coil and class E fun
KresoLiubov
Thu Dec 06 2007, 06:49PM Print
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
So i finished base and electronics for my demo coil. While waiting for my shipment of 500 IRFP460-s arrive from Japan amazed i decided to try E class just for fun with only 1 IRFP i have.
So here is setup and output on 80 VDC. Basically i charged from HV supply 400 V caps so it was like single shot but cap had enought energy for few bursts. Little HV supply cant supply enough current for coil to work constantly.
At end i decided to push the coil to 440 V ( i was scare to push electrolitycs more) and i dont think mosfet would survive even little more. At that voltage i managed to acchieve more than 35 cm sparks. WOW.
After 10 bursts i heard BANG. Poor mosfet died and that was end of fun.
I stole secondary from audio modulated SSTC. So i need to wind secondary for my coil more, make primary, hook up a full bridge and enjoy.
Im just thinking should i try secondary base feedback? Circuit is my modification of Steves self resonanting driver (mini SSTC)
1196966986 1153 FT0 Dsc01295
1196966986 1153 FT0 Dsc01296
1196966986 1153 FT0 Dsc01297
1196966986 1153 FT0 Dsc01299
1196966986 1153 FT0 Dsc01303
1196966986 1153 FT0 Dsc01306
ragnar
Thu Dec 06 2007, 11:23PM
KresoLiubov wrote ...
Wow, 500? At what price? From the supplier?
Tom540
Fri Dec 07 2007, 03:26AM
Tom540 Banned on 3/17/2009.
well since you're getting so many why not parallel like 50 of them? hehe.
KresoLiubov
Fri Dec 07 2007, 06:28AM
Matt Bingham wrote ...
Yes directly from the manufacturer. I'm not still sure about price because i only swifted the money and now waits customs, taxes, spedition and so on. I think when they come they will cost me 3 $ a piece. In Croatia one piece is usually 12 $ if you order trough companies which represent Farnell or 6 $ if you find it els were but in 99 % cases its fake
KresoLiubov
Sun Dec 09 2007, 06:27PM
Hey to all. Proceded with demo coil and have some questions.
I tested only for fun with halfbridge (waiting for my GDT cores to arrive from USA). For first time i tried secondary base feedback.
Coil works fine nd better then with antena feedback but cant draw ground sparks. Is it normal or i messed something ? I get arc of same lenght but not with same power (verry thin spark).
I pushed in heatsink and it should be fired this weekend with fullbridge and 400 V. Still thinking howmany primarly turns will be a safe margin. I also added cool line filter with fuse wich cant be changed until ling voltage is removed.
1197224866 1153 FT35513 Dsc01335
1197224866 1153 FT35513 Dsc01337
1197224866 1153 FT35513 Dsc01339
1197224866 1153 FT35513 Dsc01342
