  • Guests: 41
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
do i need a new coil?
Wed Mar 08 2006, 08:59PM Print
Registered Member #256 Joined:
i was coating my sec coil and on about the 4th coat of polyurethane it got air bubbles:( will this make breakout from the secondary more likely, or will it only affect the cosmetics of the coil? i want to know if i need to make a new coil.
Wed Mar 08 2006, 09:03PM
teslas son wrote ...
No big deal. Your secondary is fine.
dan
Wed Mar 08 2006, 10:32PM
dan Registered Member #223 Joined: Mon Feb 20 2006, 06:42PM
for cosmetics you could always just sand down the polyurethane and recoat the secondary..
Wed Mar 08 2006, 11:55PM
Unless you are building a demonstration coil for a museum
you shouldn't be concerned as your secondary will soon have many scars smile
The main thing is to get the coil working, then fine tune it
You MAY later rebuild it for cosmetics,
but you'd be more likely to go for a new/better/bigger/smaller/different design anyway.
Thu Mar 09 2006, 03:07AM
ya imm makin a smaller coil and dont think this question is worth a new thread, i have a can of "plasticote" which is like a rubber coat, would this be ok to use as a sub for clear coat?
Thu Mar 09 2006, 12:48PM
plasticote should work fine
Thu Mar 09 2006, 06:11PM
great i will coat the coil with that then. just making a small coil, i havent seen any sparks for months and i want to so thats good, also i have a question bout my nst, i was in the process of unpotting and acidentally cut three turns on the primary, is this ok, if i need to i can rewind the primary i was thinking just remove the turns i cut out, will this make a big jump in the output voltage and possibly break down the secondary insulation?
Thu Mar 09 2006, 07:54PM
Depends how many turns you have to get out, to remove the three cut turns. It is better for the NSTs to be run inside the specs.
-connect the secondary to the mains and measure the output voltage from the primary (the NST will work as a step down transformer). find the difference from the mains voltage value.
-wind 5-10 turns on primary side. With the secondary connected to mains measure the output voltage from this new winding and calculate the number of turns/ volt.
-find the number of turns needed to match the primary to the mains voltage, and wind them using wire with the same or bigger diameter.
-insulate the windings.
Thu Mar 09 2006, 08:41PM
would it be ok to just like solder on some more wire and wind the turns again? my thinking would be that that would be ok, beacause many transformers have taps and that would essentially be a tap. also with shunts, is there a general thing that says how much more current you can get by removing a shunt?
Thu Mar 09 2006, 09:15PM
Yes, you can splice turns on a secondary with no problem. Just be sure to keep the splice point as "flat" and neat as possible.
