  • Guests: 72
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
SSTC: base feed transformer
Mon Dec 03 2007, 03:49PM Print
So has anyone tried this actually? Basically you use a step-up ferrite transformer connected to your bridge that feeds the base of the secondary winding. It should have two advantages over "direct drive" primary winding: 1) no pri-sec flashovers 2) greatly reduced magnetizing/reactive current.
One disvadvantage would be that the ferrite xfmr would have to handle the power of the coil so it would be probably quite big and xpensive. But for small <400W coils the transformer could be a flyback core, core from SMPS etc.
I think I will try it but I need some help on design of the transformer, how big pri/sec ratio should I aim for, how many prim. turns etc.?
Spedy
Mon Dec 03 2007, 04:27PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
Interesting concept, like a ferrite-cored Tesla Magnifier. I would do some research on those before getting into this project, but It'll sure be cool!
Mon Dec 03 2007, 04:31PM
Alan Sharp tried it in the 1990s. It was a disaster, IIRC.
We know a lot more about solid-state coiling now, though. But bearing in mind the required fairly high base feed impedance, the transformer design will probably still be pretty difficult. You might struggle to get low enough leakage reactance, low enough self-capacitance, and adequate flashover clearance at the same time. Bear in mind that flybacks self-resonate at frequencies much lower than Tesla coils.
Marko
Mon Dec 03 2007, 07:02PM
Hey, I just needed a thread like this.. wink
I'm also very curious about possible use of a transformer.
I don't think transformer needs to have high turns ratio, like 1:10 should give plenty of voltage to drive some good power.
Regarding coupling, it should in any case be much better than air core smile
But with proper winding technique it can be reduced to nil.
From what I know there should be much less stress on the mosfets and even heavy hard-switching (audio modulation and etc.) should work much better for higher powers.
I tried to get Chris Link2 to think about the idea, but I don't think he got me seriously.
If magnetizing current could be reduced to negligible value, I thought that audio-modulation could be much easier. The driver behind the ferrite transformer would basically be a class D amplifier.
I'd really like to see a CW coil pumping half a meter long audio modulated arcs. wink
But all this needs expert opinion...
Hmm... as far as I see, he used series capacitor on the transformer primary? I don't think DRSSTC with ferrite transformer would fare well.
Marko
Dr. Drone
Mon Dec 03 2007, 09:25PM
shades
Marko
Mon Dec 03 2007, 09:51PM
Christopher Miles wrote ...
Marko wrote ...
Marko
Ohhhhhhhhhh I am interesting for sure; however, I have a few projects that will fill my plate for the next year, wheeeeeeeee.
Hey, why not build a little proto yourself and see if you can keep the magic smoke in?
If a little coil works, maybe can make bigger? wink
I can fund the project as know $ is tight. I am sure we have just about all you need in our garages in Az. to start the project out? amazed
Cheers,
Ch
Sir, I'll try something in along with my SSTC development! wink I actually have a ready transformer I could try this with, although I fear output voltage may be a bit too high...
And I could try one of smaller secondaries with it. I need more of Steve's opinion, though.
If basic magnifier proves to work well I can go to audio modulation, but that's probably not a close future,
ill
BTW, you have your big VTTC to finish! smile
Marko
Dr. Drone
Tue Dec 04 2007, 07:05PM
shades
Reaching
Tue Dec 04 2007, 08:09PM
hrhr, thats a really nice idea and i have to try it out immediatly.
i have some half and fullbridges already finished and 2 really large ferrite cores which can handle 3kW+ each .
lol, just think about a fullbridge with smoothed dc running on 200khz in a 1:10 transformer, feeding the base of the resonator with 3kV+ .. thats weird lol but i like it
colin heath
Tue Dec 04 2007, 10:19PM
colin heath Registered Member #123 Joined: Fri Feb 10 2006, 12:58PM
hi all,
This has been done successfully. i haven't got the link to it anymore but will try to find it on net.
It was quite a powerful coil
heres the link on hacked gadgets as his site appears to be gone. Link2
cheers
colin
Bennem
Wed Dec 05 2007, 06:42AM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
His name is John Tomacic.
He had a web site with pictures and some information
on his SSTC coil.
I'm not sure if the site is still up and running though.
Mel.
