  • Guests: 36
DRSSTC problems
Linas
Sat Dec 01 2007, 02:52PM Print
Hi everybody
I decided to make DRSSTC because sstc blows mosfets, and i dont want spend money for that.Is it posible to make drsstc, and don't have problems? if yes, what kind of scheme use ?
confused
Danielle
Sat Dec 01 2007, 07:26PM
the probability of you having no problems is slim to none but a designe that has been used successfully over and over is Steav Ward's DRSSTC 3 Link2
also you will have to spend money to make the initial investment, costing you about $200-$500 to build a reliable and good looking one. If you can go with junkyard parts then reliability falls and you will be spending more in the long run but you could build it for less than $200.
good luck,
Danielle
Sun Dec 02 2007, 04:42AM
If you cant get a SSTC to work reliably, then you need to go and figure out what the problem is. Just moving on to a more advanced project isnt likely to work any better.
Linas
Sun Dec 02 2007, 08:06AM
Steve Ward wrote ...
sometimes my sstc runs wrey good, with no heating, but sometimes sstc blow mosfets, and i don't know whay, maybe overcurrnet cry but mosfets "can" runs on 44A cry
MOT_man
Sun Dec 02 2007, 08:35AM
I've never tried building a DRSSTC before...and it does look very cool. Hey, I wonder how one would increase the current draw from the mains and larger sparks --- is it simply getting a larger IGBT / primary capacitor??
Linas
Sun Dec 02 2007, 09:02AM
sory, i don't blow mosfets, whey just break, and make short circuit,(3 times they blows cheesey )
But whay they go off ? driving is very good, have GS protection (13V zeners), have overvoltage protection , and good heatsin...they are "eating" 3-4A, and 800W (220V AC)
here is my sstc GDT connected direct to transistors, without 12 om rezistor, and with 20nF load, usually my mosfets is 2*4nF :)
1196586119 1143 FT35260 Load
Sun Dec 02 2007, 05:45PM
Linas wrote ...
It's a matter of keeping in resonance, your fixed frequency oscillator can't keep in tune when you detune the coil (which happens all the time.) so the mosfets have to switch reactive current and die. Switch to a resonant driver.
Linas
Sun Dec 02 2007, 05:55PM
someone show just rezonance controler withuot interupter :) please, and thanks
