  • Guests: 74
High voltage alternator/generator?
atomicthumbs
Fri Nov 30 2007, 10:36PM Print
atomicthumbs Registered Member #498 Joined: Sun Nov 19 2006, 06:00PM
I'm looking for some sort of alternator or generator that can directly generate at least 15 kilovolts.
It needs to be drivable by an engine.
Does anybody know of such a thing?
It's for "special purposes". wink
Bjørn
Fri Nov 30 2007, 10:50PM
Yes, but until you specify a power level there is not much sense in replying.
Dr. Slack
Mon Dec 03 2007, 10:19AM
You could consider a magneto, try an old motor bike or aero- engine, but they're probably about as common as rocking-horse dung these days.
Chris
Mon Dec 03 2007, 12:44PM
Chris Registered Member #8 Joined: Thu Feb 02 2006, 04:34AM
You could build a Bonetti electrostatic machine (google if you don't know what one is). They are a DC constant current source, so the voltage they output depends on the load resistance, and will go as high as it needs to maintain the design current until something arcs over or resistive/corona losses become significant enough. In the past large multi-disc ones were even used to power x-ray machines, so they can definitely do high power and even relatively high current as far as electrostatic generators go (10's of mA no problem, you could develop one for 100's of mA if you wanted but it would have a lot of discs). The current depends on the surface area and tangential velocity of the discs and they have no trouble developing hundreds of kV, or MV, if the size allows. 15kV would actually be quite low for such an electrostatic machine, but it will work fine depending on your current needs.
