  • Guests: 73
OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
01/25 Patrick (44)
Mini SSTC
Tom540
Mon Nov 26 2007, 07:34AM Print
Tom540 Banned on 3/17/2009.
Okay, I started building this thing on Saturday just for the hell of it. I had an old secondary wound with 36 awg wire 2.5" x 10" so I decided to cut it in half and make a small coil out of half of it.
It's got a half bridge of IRF450's and a voltage doubler all crammed into a computer power supply case. Secondary is 4.5" long with a 4" sphere on top. It uses secondary base feedback and runs at 500KHz with the topload. The sphere is too big and I'm thinking of replacing it with a small toroid.
I did manage to kill the fets after taking the video. In the last two pics it was running off ~75v on the variac. The secondary gets warm after shorts runs.
Here's the pics:
1196058613 487 FT1630 Sstc All
1196058641 487 FT1630 Sstc Side
1196058663 487 FT1630 Sstc Top
1196061453 487 FT1630 Sparks1
1196061470 487 FT1630 Sparks2
Mates
Mon Nov 26 2007, 08:36AM
Tom540 wrote ...
Beautifull litle "dildo". It's a pity that the FET based bridge topology is so fragile (I destroyed my IRF450 half bridge immediatelly after turned it on)...
Marko
Mon Nov 26 2007, 10:07AM
I really don't have a clue how you guys get out at all with these tiny primaries. Have you tried calculating magnetizing current? What are dimensions of your primary coil?
I wouldn't want it to be >3 amps for IRFP450's and from glance I'd use like 15 turns or more.
Tom540
Mon Nov 26 2007, 03:21PM
I didn't calculate anything I just started slapping it together. I would have put more turns but thats all the wire I had in that size for the primary. I'll probably get some slightly thinner stuff and put more turns on it later after I replace the bad FETs.
I just ran out of the FGA40n60's I'm pretty sure they would be able to handle the 500KHz this thing runs at and they're much more heavy duty.
Tom540
Tue Nov 27 2007, 06:50AM
A small update. I made a tiny tape toroid. I'm not really happy with the spark length and it arcs to the primary past 90 volts on the variac.
1196146176 487 FT34939 Little Coil
Mates
Tue Nov 27 2007, 09:15AM
Tom540 wrote ...
Put a protection plastic disk on your primary... you can use old LP - just cut a hole inside with some simple resistive wire based cutter (I've made one from old 30V 200W transformer, 20W 1ohm resitor in 5 minutes)
BTW: I like the sparks
Dr. Drone
Tue Nov 27 2007, 05:04PM
shades
Tom540
Tue Nov 27 2007, 05:35PM
Christopher Miles wrote ...
I am down to 3.5 turns and have not blown a FET yet in 2 years. This coil must have 100 hrs on it. It now is at the local power company still running demo's.
Could go down to 2 turns but the FET's start to cry a bit @ Link2
Use a big fat copper primary.........................was a bitch to bend the copper however.
Your fets are 48 amp lol. I was thinking about getting some 44n50's off ebay for this but since I didn't blow them why bother?
Speaking of the fets. it turns out I didn't blow them. I blew the ultrafast diodes. I didn't replace them I just cut them off and it works fine.
I think a big fat copper primary might be overkill for my 4.5" secondary, hehe. I do have some 10 awg solid strand wire. I could just have that wind around without a former.
Bauerb2
Tue Nov 27 2007, 09:27PM
Bauerb2 Registered Member #973 Joined: Tue Aug 28 2007, 07:32PM
reminds me of my topload
1196197012 973 FT34939 Coil 001
that primary cable on mine is insanely thick, and was a pain to make. Is it alright if i use stranded copper cable instead of copper pipe/solid copper wire?
anyway, you're ahead of me, i have yet to run mine past 40V on the variac. It works great with all 9 turns and the mosfets only get slighty warm, while giving 2.5" discharge from a needle point. I also use sec base feedback instead of antenna, i think it runs smoother. Mine runs at 330kHz, using a fullbridge of IRFP460's which you can see on the bottom right. For the topload i used flexible black hose covered in Al tape.
I've used down to 2 primary turns on some of my earlier tests, only to see the current spike up, the mosfets heat up, and the streamer length go down a bit. your primary seems very close to the topload, which might be why it has arced there.
nice coil btw
-Andrew
Tom540
Tue Nov 27 2007, 11:47PM
Yeah I think that is probably overkill. My primary is made from CAT5 cheesey 2 twisted pairs paralelled.
What size is your secondary?
nice coil btw
Thanks, I was using 6 turns but the FETS seemed to get a little hot. I'm not too happy with the spark length considering I'm using a full wave doubler on this thing.
