  • Guests: 15
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Another first tesla coil...
Firnagzen
Wed Nov 21 2007, 08:56AM Print
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
And it's a SSTC. That's because I don't like the concept of the SGTCs.
Well finally. After about a year of waiting, my examinations are finally over and I get to start work...
I've finished soldering the driver board, with the interrupter.
That's the GDT at the side, which, I have to say was a pain to wind. The cable is so stiff... I used the entire Cat-5 cable so that I can parallel the wires for more current; I don't trust that thin cable. The Cat-5 cable and twisted cables go to a four way switch and two variable resistors, for the interrupter, and that big yellow thing is the dc blocking capacitor.
Here's a mockup of the half bridge, leaning against the heatsink. (The reflection of the flash... Ouch.)
I was lucky enough to find a terminal strip which fits the MOSFETs exactly. As in, the legs slot in nicely!
I'm just waiting for the wire for the secondary and the driver chips to arrive now. cheesey
Tom540
Wed Nov 21 2007, 04:17PM
Tom540 Banned on 3/17/2009.
LOL, yeah I can see why that was a pain to wind. Probably overkill for thsoe FET's.
I only use part of the cat 5 cable. I wind one two pairs twisted lightly together then I parallel the white striped ones. Works perfect. About 15 turns.
Shaun
Wed Nov 21 2007, 05:37PM
You don't have to worry about current problems in the CAT5 cable; it is much more likely to die of overvoltage-related arc-overs and shorts. Not yours specifically, just any GDT in general.
Firnagzen
Thu Nov 22 2007, 12:53AM
Really, that wire looks awfully thin, though. I have succeeded in melting some wire insulation off in my PSU before, and those wires were much thicker. Admittedly I was running at about 5A, but meh...
Zum Beispiel
Thu Nov 22 2007, 12:54PM
Wire size is fine. most people use Cat-5 with no problems. I would take the outer insulation of though... just use the inner conductors.
Firnagzen
Sat Nov 24 2007, 01:28AM
Uh oh, here's a problme. My order for the TC4420s has been delayed until January 08! I don't suppose anyone can think of another supplier other than RS? I live in Singapore, so quite a few suppliers are alredy out.
Crow187
Sat Nov 24 2007, 03:53AM
Crow187 Registered Member #795 Joined: Mon May 21 2007, 06:04PM
You can look for ucc37321 / ucc37322 perhaps you can get those better!
Lukas
Firnagzen
Sun Nov 25 2007, 01:36AM
That's even worse, because UCCs are even less common than the TC4420s... That I've seen so far anyway, though I could be wrong.
Marko
Sun Nov 25 2007, 02:03AM
Using gross number of turns like that on your GDT will only make things worse due to lots of additional leakage inductance.
For core of that size you aren't going to need but few turns.
Calculate after thedatastream's site and don't use more than + a turn or so. James actually already gave a good margin.
Wire thickness is nothing to worry about. You anyway put a resistor like 2 orders of magnitude bigger than the resistance of the wire in series.. We use CAT 5 just because of insulation and handyness.
Better than it would be to use shielded cable with shield as a primary... but CAT5 is good enough for most things.
