  • Guests: 52
MOSFET VS IGBT
HvHaxor05
Mon Nov 19 2007, 08:24PM Print
HvHaxor05 Registered Member #1116 Joined: Tue Nov 13 2007, 02:11AM
Im trying to build an high budget sstc driver i want it to be very universal should i use igbts or mosfets.
Mon Nov 19 2007, 08:27PM
For SSTC use definately mosfets, they have faster rise and fall times> less switching losses.
EDY19
Mon Nov 19 2007, 08:43PM
If it is a classic SSTC driver, I would use mosfets. Switching times are much less than most IGBT's, and you will lower the losses due to switching transitions. I believe Steve has played around with some 80N50 MOSFETS that have held up through a lot of abuse, if you're going with a high budget, i'd consider getting some of these.
nrhoades
Mon Nov 19 2007, 11:18PM
nrhoades Registered Member #610 Joined: Wed Mar 28 2007, 09:44PM
MOSFET drive waveforms are similar for both turn-on and turn-off. IGBT's have a tail current during shut-off you need to be aware of. You really only need to start thinking about IGBT's once you move into the realm of higher voltages and more throughput.
Gavin
Tue Nov 20 2007, 03:23PM
Gavin Registered Member #478 Joined: Tue Jun 20 2006, 11:57PM
Is it not the case that at high currents the on-resistance of the MOSFET drain-source channel becomes significant in dissipating power (for increasing current, I^2R losses), while an IGBT has a fairly fixed VCE (3V approx.) and so the power dissipation is lower at these conditions? I guess this only really comes into play with DRSSTCs?
Tue Nov 20 2007, 09:48PM
Universal driver = sucks over a bigger range.
Design for an application... make up your mind already and just build it. Its stupid to use big IGBTs for a little coil that runs at high frequencies, likewise, dont use wimpy fets on a monster coil.
Now, if what you really sort of meant was "i want a SSTC driver for 100-2000W of power at < 250khz" then that is a perfectly good design criteria. But, if its more like "i dunno if i will drive a coil at 100khz or 1Mhz", then there really isnt going to be a solution that works great for both cases.
I too suggest MOSFETs if you are doing regular SSTC type stuff. Depending on your line voltage (120V or 240V) the IRFP260 and IRFP460 are pretty standard parts.
