  • Guests: 60
primary from alu foil
Mates
Sun Nov 18 2007, 11:05AM Print
Hi people,
For those of you having troubles to get material for primary (my case) I just developed a way of producing very cheap and quite effective primaries. It is based on Alu foil (the fat one for grilling) which is firstly wrinkled and than rolled between your hands (the fat alu-foil is not fragile so it can be done very easily). You can get almost any length (limited by the total lenght of the foil) and the surface of such conductor is huge (I guess the skin effect must be very low). Next advantage is that it is not isolated (like most of the wires you can get for this purpose) which alows easy tuning...
I tested it on my coil and works well...
Cheers Mates
1195383937 1025 FT0 Pict2938
1195383937 1025 FT0 Pict2942
Tetrafluoroethane
Sun Nov 18 2007, 03:38PM
Tetrafluoroethane Registered Member #127 Joined: Fri Feb 10 2006, 03:36PM
Creative, but it seems like a lot of work. I would have opted for an old cord off a lamp or something. But I like the way you think. cheesey How did you end up making connections to the foil (tap and end) since it has such a rough surface?
Marko
Sun Nov 18 2007, 04:09PM
I made an Al foil high-skin conductor using layers of kitchen Al and polyethylene foil rolled together and twisted. There needs to be insulation between AL foil layers in order to get all skin out of it.
Still I don't think it's good for anything but special applications... at currents we generally use with SSTC's we don't generally need an overkill like such.
You might try including the PE foil also.
Mates
Sun Nov 18 2007, 09:05PM
OK, I tried new one (needed higher coupling). The total time for making the primary aprox. 10min including the winding... For holding the primary on the tube I'm using the hot glue pistol...
Pictures with details
1195419927 1025 FT34448 Pict2943
1195419927 1025 FT34448 Pict2948
1195419927 1025 FT34448 Pict2950
BTW: The lamp is powered wire-less from the coil
Zum Beispiel
Sun Nov 18 2007, 09:29PM
Heh, thats a good one. Maybe a bit too ghetto for my tastes, though. wink
Mates
Sun Nov 18 2007, 10:24PM
Zb wrote ...
"Ghetto" - that's cool description for all my HV stuff. Maybe I take it as a new nickname... shades
Here is one more pic after litle bit of tuning...(Device: single IGBT class E coil - power consuption 350W)
1195424565 1025 FT34448 Pict2952
