  • Guests: 62
GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
electrolisys of water
rp181
Tue Nov 13 2007, 03:15AM Print
Im trying to get hydrogen from water, my current setup is 2 bottles connected with PVC ( hotglued). The top lid have holes, and hollow copper tubes are stuck down, these are the electrodes. Above the negative electrode, a glued a 2 liter soda bottle and ran 400ma 12v through. I cant tell if thi is working, am i doing it right?
Oh ya, i mixed the water with some baking powder, originally did salt in a bowl and it worked, but the i found out it made chlorine, dont want anything poisinous.
Cwazy
Tue Nov 13 2007, 03:30AM
Cwazy Registered Member #1106 Joined: Thu Nov 08 2007, 01:15AM
i sent u a pm regarding a how to for making one. its another forum so i dont wish to post it here.
Wed Nov 14 2007, 03:57PM
I would ditch the baking powder and use NaOH, it doesn't vanish from the solution during electrolysis and it works as well as salt. No toxic chlorine either. For electrodes use graphite or high grade stainless steel, otherwise they will corrode away.
Bjørn
Wed Nov 14 2007, 05:05PM
You also need to be careful if you collect any significant amount. Hydrogen ignites easily and is explosive over a large range of mixture ratios. Make sure you start out with the bottle completely filled with water so there is no air in it.
rp181
Thu Nov 15 2007, 12:14AM
i tried using mechanicle pencil lead (.5mm) with salt earlier before this post, but when i checked it, the graphine on the cathode melted, and there were black bubbles above. what happened?
will the silicon steel from transformers work well (I-part).
as for collecting, not collecting much, mainly just expirimenting.
Shaun
Thu Nov 15 2007, 12:46AM
The mechanical pencil lead did not work because it doesn't have enough surface area. Only lab electrolysis demos use rods as electrodes; when somebody is serious about collecting H2 or some other electrolysis product, they use plate (or large dia tube) electrodes.
The measure is Amps per square meter, or more commonly mA/mm^2. The lower this is, the less stress on your electrodes.
More surface area is also better because you will decrease resistance between the 2 electrodes which will allow more current flow at same voltage, yielding more H2 faster.
Oh and BTW when I used to electrolyze stuff, I just let the H2 mix with the Cl in the collecting container. You get a real nice bang out of that, just be sure to stay away from the resulting HCl gas! (apparently strong UV can ignite this mix, too, but I've never had that happen, even in direct sunlight)
Bored Chemist
Thu Nov 15 2007, 06:51AM
Also, mechanical pencil "leads" are held together with plastic/wax.
I'm sure a web search will tell you how to get the carbon rods out of batteries. These work much better.
rp181
Sat Nov 17 2007, 12:39AM
ok, so i got 2 rods from 2 D-Batteries, im planning on using baking powder-water mix at armound 3 amps 12v. When u first get out the carbon rod, is anything required to make them safe? dont wanna touch till im sure :). anything i should be aware of?
Bjørn
Sat Nov 17 2007, 03:38AM
Give them a wash and wipe them really clean with paper. Then wash you fingers. That has always worked for me. The main thing that can go wrong is that you get electrolyte on your fingers and put them in your eye or mouth.
Remember that lower voltage is more efficient, you will find more posts about electrolysis by searching the forum.
JordanAutomations
Mon May 19 2008, 08:05AM
JordanAutomations Registered Member #1487 Joined: Thu May 15 2008, 09:52PM
Growing up, I think electrolysis was one of my favorite applications of chemistry. The carbon rods from D batteries were always good. Though I found out that the local jeweler used thicker and longer carbon rods for getting the slack out of their melting pots. Those worked real well.
I generally used carbon for the positive, where the oxygen would be. I would use a stainless steel rod for the negative electrode. Stainless didn't break down to particles as fast as the carbon did, and would last long. But the oxygen side would rust anything metal.
