  • Guests: 29
OiD (38)
jolty (50)
Baran (29)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
GDTs and dead time
thedatastream
Mon Nov 05 2007, 09:22PM
*toot*
Tue Nov 06 2007, 03:16PM
I managed to minimize the overshoot by winding trifilar magnet wire on a smaller core.
Is enameled wire ok for a GDT? I was previously always using PVC wire since I was worried that enameled wire won't stand the full mains voltage at several tens KHz..
Wolfram
Tue Nov 06 2007, 04:18PM
I wouldn't recommend it. I used it for some time for driving a half bridge, and it worked for a long time, until it arced over and killed the FETs.
Tue Nov 06 2007, 07:25PM
I saw some screened stereo audio cable and I thought it could be good for a GDT... I wound 8 turns of it on the core and voila- the problem is solved! smile
I used the shields in parallel as the primary and the inner conductors as secondaries.
1194377106 152 FT33742 Gdt2
1194377106 152 FT33742 Gdt3
