  • Guests: 55
01/12 RoV IW3IPD (63)
Jacob's Bi-ladder
Tesladownunder
Sun Nov 04 2007, 07:00AM
Correct.
We have a winner. (although the Overclockers forum got it first)
There are three one inch NIB magnets behind the lower JL with North pole closest. The left terminal is positive and the force pushes it down at a much faster rate than the simple air convection makes it go up.
OK well that was fun and you scored a pass.
However, after some thought I realise that there is another way to achieve an identical photo WITHOUT magnets. It is tricksy and complicated and should work perfectly. So for a distinction, how could I do this?
TDU
1194159560 10 FT33703 Jacobsbiladdermagnets600
Spedy
Sun Nov 04 2007, 03:47PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
With electro-magnets? lol
I don;t know
Sun Nov 04 2007, 04:14PM
Put the bi-ladder on its side and turn your camera. the air currents at right angles would do nothing.
Tesladownunder
Sun Nov 04 2007, 04:22PM
Nik wrote ...
Slightly in the right direction of the answer I am looking for.
Air currents at right angles still blow the hot air away and prevent the spark going to the wider end.
TDU
Sun Nov 04 2007, 06:43PM
The lorentz force should keep the arcs moving away from each other if the bi-ladder was on its side without magnets. Other then that maybe having the powersuply wires behind the arc in the same way that some railguns have the "magneticly augmented" rails.
Tesladownunder
Sun Nov 04 2007, 11:26PM
Nik wrote ...
Yes Lorentz forces will do it but not at this power level. Try it yourself.
I do recall a railgun with a crossover arrangement of supply wires to increase the Lorentz force. Might work but there are insulation factors to bear in mind which limit the number of windings.
Not what I was thinking of though.
TDU
CT2
Mon Nov 05 2007, 03:29AM
If you put it on its side, and bent the ladder wires up slightly. So looking down on it from straight up it would appear to be flat, but its actually on an angle... maybe that is enough that the heat could pull it out and up?
Tesladownunder
Sat Nov 17 2007, 02:47PM
No-one has worked out the way without magnets.
I won't have time to try it so here it is.
Fix the camera, light source and Jacobs bi-ladder in a box with flexible HV leads.
Use a long exposure. Half way through the exposure, turn the box upside down.
The final exposure will have sparks in both directions with constant lighting.
You could also get a similar look by blowing air up and then changing and blowing down half way through the exposure.
Simple.
TDU
Firnagzen
Sun Nov 18 2007, 01:40AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
But then they'll be a motion blur (right?) in the image. And it won't look as good.
Tesladownunder
Tue Nov 20 2007, 06:01AM
No motion blur as the camera, lights and JL are all fixed in the box. Lighting is as good as you want to make it. It can look fine.
There will be some ladder effect on each side trying to go the wrong way. This setup is best done without the central electrode to get the bidirectional effect.
TDU
