  • Guests: 65
01/12 RoV IW3IPD (63)
ZVS Induction Heater (With pictures and video)
CompWiz
Thu Nov 01 2007, 10:08PM Print
CompWiz Registered Member #1038 Joined: Mon Oct 01 2007, 08:02PM
I used my ZVS flyback driver to make an induction heater
Cap =2uF
Voltage=12v
7+7 turns
videos:
or:
EDIT: I think i posted this in the wrong place...
1193954715 1038 FT0 S6301402
1193954715 1038 FT0 S6301396
1193954715 1038 FT0 S6301405
1193954923 1038 FT0 S6301404
Andrew L.
Fri Nov 02 2007, 10:06PM
Andrew L. Registered Member #515 Joined: Sun Feb 11 2007, 02:06PM
Quick and dirty induction heater ... niceee cheesey
atomicthumbs
Mon Nov 05 2007, 09:28PM
atomicthumbs Registered Member #498 Joined: Sun Nov 19 2006, 06:00PM
So all you need is an HV cap and a flyback?
Hmm....
What kind of cap did you use? I can get the flyback easy enough but have no idea of anything else :P
Wolfram
Mon Nov 05 2007, 10:24PM
Flyback? There's no flyback involved here.
CompWiz
Mon Nov 05 2007, 10:54PM
I just used the ZVS Driver and instead of winding a coil around the fly back core
I just made the coil like in the picture.
The ZVS driver schematic is here: Link2
1194303063 1038 FT33665 S6301406
1194303063 1038 FT33665 S6301407
1194303063 1038 FT33665 S6301408
Use a big heatsink and fan or your mosfets will end up link this one!
1194303063 1038 FT33665 S6301409
Ken M.
Mon Nov 05 2007, 11:42PM
I use big ones like that! They don't look like that unless the feedback circuit has a "Hiccup" then both fets fire at same time and dump 160V at upto 20A across them, then the silicone on the inside gets spot welded ino a nice blob of metal inside a plastic case.
CompWiz
Mon Nov 05 2007, 11:47PM
The other fet still works.
that thing emitted a rather large cloud of smoke right at my face when it went
"POP sssssssssss"
I was also using a smaller heat sink
Danielle
Tue Nov 06 2007, 01:56AM
I built it the only problem I had was the cap failed I only used small TO-220 MOSFETs 150V 80A they didnt get hot with small heatsinks. it worked well though.
CompWiz
Tue Nov 06 2007, 04:58AM
I just noticed that i used bigger wire for one side of the coil!
maybe thats why it gets so hot..
It stays cold when running flybacks even at 24v(although the flyback got almost hot enough to burn me)
Tonic
Tue Nov 06 2007, 08:02PM
Rocketry76 wrote ...
Probably it's caused by a lower R(ds)on. IRFP250 has 85mOhm. And your?
