  • Guests: 36
RoV IW3IPD (63)
01/13 si2030 (62)
Marx vs. WC multiplier
Mon Mar 06 2006, 09:59PM Print
Other than the design differences, is there any other differences (efficiency, peak volts attainable, current) between these two high voltage devices?
Mon Mar 06 2006, 10:04PM
A marx give a high curretn pulse where as a CW gives more continious current.
Wolfram
Mon Mar 06 2006, 11:55PM
An other major difference is that marx generators operate from DC and voltage multipliers operate from AC.
Tue Mar 07 2006, 12:23AM
Marx generators are high voltage impulse generators typically single-shot. Cockroft-Walton multipliers are used to generate high voltages, but at very low currents.
Simon
Tue Mar 07 2006, 12:58AM
Although CWs have been made to extremely high voltages, a marx generator can be cheaper as the voltage goes up, especially for amateurs. A higher voltage marx essentially needs wider gaps and thicker capacitor dielectric. A CW in practice will probably need diodes with higher voltage ratings - hard to get for many people.
Tue Mar 07 2006, 04:31AM
Let's say I wanted to build a Marx Generator. I set up each stage of resistor/cap/SG. How would I "tune" it to fire just right? Would I adjust the spark gap of stage one until it just fires near full cap voltage and then adjust the next spark gap to fire just below the peak charging of cap2 + the discharge of cap1, etc?
Dr. Slack
Tue Mar 07 2006, 08:06AM
There are two mechanisms that make the other gaps fire once one gap has fired. Stray capacitance to ground raises the voltage on gaps adjacent to a arcing gap, and UV from the first arc ionises the air in the other gaps IF they are all in a straight line and can "see" each other, regardless of which gap goes first.
If you are not too bothered about controlling the firing time exactly, make all the gaps the same size, and wait for the first one to strike as you charge. In practice, the voltage on the upper gaps will be less than that of the lower gaps due to the charging RC time constants, and corona losses if the voltage is high enough, so it is still likely to break down bottom gap first.
If you do want to charge, wait, then fire, make the first gap a triggered gap.
Dr. Shark
Tue Mar 07 2006, 08:49AM
There is another important difference between CW and Marx for the amateur who wants to get the biggest bang for the buck: With a CW you have two columns of capacitors, so the maximum peak voltage attainable is only half of the total your capacitors can stand. I.e. for a given amount of caps, a Marx gives you twice the voltage. In addition to that, you have much less corona problems, since you only reach the peak voltage for a few 100ns.
High voltage resistors and diodes are about equally hard to get, so thats not really a point IMO.
Wed Mar 08 2006, 05:54PM
why with a WC is it only 1/2 the voltage rating of the capacitor?
If I wanted to power a WC or MG, would a neon transformer be acceptable for the WC? Would an ignition coil/driver be acceptable for the MG?
Marko
Wed Mar 08 2006, 06:20PM
Rectfied iggie may be a try for MG but it gives out very low current and it would take centuries to charge and fire marx (or corona will eat power faster and it wouldnt fire at all).
Usually rectified flybacks, NST's and OBT's are used.
For CW multiplier high frequency supply is used (flybacks at most) so we can use small caps and it gives continuous HV output.
