  • Guests: 38
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
WaveRider (62)
Njubster (34)
10/30 Aragorn (41)
10/31 Tor (40)
10/31 RussT (67)
Question re: Calculating V drop across spark gaps, components
thrival
Fri Oct 19 2007, 09:06PM Print
thrival Registered Member #1019 Joined: Sat Sept 22 2007, 02:39AM
Assuming the typical ignition coil circuit where spark jumps a gap,
how would a person calculate:
1) the V drop across the gap?
2) the V drop across any component in series with the gap, when breakdown occurs?
I have 4 loaner books on HV engineering, go into great detail re: the physics of
spark discharges, but not how value of components are affected. In days of early
radio, was well-known that spark gaps converted HV, low current, to low V, high current.
Can anyone refer to me to sources where and how the latter values are quantified?
Thank you
Fri Oct 19 2007, 10:10PM
The voltage drop across anything connected to the secondary in a circuit like that will be negligible. The voltage drop across D1 will be about 10v (roughly 2v times the number of diodes in series), and the voltage drop across the spark gap will depend in the current in the gap. If you have a nice high current running, it should be well under 100v.
thrival
Fri Oct 19 2007, 11:30PM
Dear *** :
I only intend to use one diode. I know diodes typically have V drops from .7 to maybe 10V
depending upon type. Do I need a HV diode for this if most all the V drop occurs across the
spark gap, or could a lower rated diode serve? How do you come by your figures of 100V
across the spark gap, et al ? Actually current out the ignition coil in this case will be pretty
low, <200 watts. Thanks again!
Simon
Fri Oct 19 2007, 11:40PM
A spark or arc happens when you ionise air (free electrons from nuclei) and make a conducting path. This can happen two ways: heat or electric fields.
When you first apply a high voltage to air, the air ionises and you get a spark. This takes the Paschen voltage to happen. As soon as current flows through the air, this heats it up a lot. Heating the air reduces the voltage needed to ionise the air.
Calculating this stuff is difficult.
Sat Oct 20 2007, 12:21AM
There is no such thing as a single diode that can handle >10kv, hv diodes are made internally as a stack of smaller diodes inside a single package.
Sat Oct 20 2007, 12:46PM
The voltage rating of the diode is for the reverse direction anyway, when it's not conducting.
As for the spark gap voltage, look at this:
thrival
Sat Oct 20 2007, 12:59PM
Dear *** :
Well I believe you, have no reason to doubt that, but do I need a diode stack?
Again, the diode is ONLY forward biased and will never experience a reverse
voltage. It's a DC circuit and the diode is redundant from that perspective, but I still
need it for other reasons, hence the need to calculate the V drop across it during forward
bias, when the arc has formed and is conducting. Arcs lower the V in a circuit by acting
like a big resistance. That's why what comes out after is lower V than what went in.
I know voltage across gaps is determined by distance and breakdown of the air, and that
there's a resistance drop across the gap when it occurs. But now that an arc has formed,
how does one calculate the V drop across other components in that series circuit, while
the arc exists? If you say I need a 10kV diode stack, OK; I'm just trying to understand
how you came by that figure
likewhat
Sat Oct 20 2007, 03:24PM
likewhat Account deactivated by user request on 6/11/2009.
Registered Member #1071 Joined: Fri Oct 19 2007, 02:13AM
It seems like it should just be an ohms law type thing to me. The voltage drop across a component should just be related to its resistance like in any other circuit. At some point when things are small and the voltage is high you might just be arcing across stuff so a "high voltage" one of them is needed. I dont think the presence of an arc should matter if you are worrying about something else in the series circuit. You should be able to model everything else in the circuit as a black box feeding some voltage and current through the component in question.
Sat Oct 20 2007, 04:45PM
I suppose I misunderstoodd you, if you are using a a single low voltage diode you can assume about 2v drop across it.
thrival
Sat Oct 20 2007, 05:43PM
Thanks guys, appreciate the input, but still need to calculate.
Imagine for example, we have a source putting out 35kV, but the spark
gap is moved close enough to break down at 10kV. Where does the other
25kV go? Across the diode? If the diode is the only other R in the circuit,
then I'm afraid it might be toast.
If someone can tell me they know for certain, that forward-biased, low voltage
diodes can be placed in HV DC circuits without worry (within rated amps), then
I'll be very happy.
