  • Guests: 55
HV water bridge?
Sat Sept 29 2007, 09:12PM Print
"Water forms bridge when exposed to high voltages"
hmm... interesting. wonder if you could make a n mile long bridge this way, in a vacuum? :)
"Waterworld" anyone? lol
-A
Alex
Sun Sept 30 2007, 12:19AM
Alex Geometrically Frustrated
Registered Member #6 Joined: Thu Feb 02 2006, 04:18AM
Hah, that's pretty neat. I think gravity would be more of a problem than the breakdown voltage of air. You can only put so much current through there to hold up the bridge before you get boiing water.
Bored Chemist
Sun Sept 30 2007, 11:39AM
Water in a vacuum? That would be interesting.
Andrew L.
Sun Sept 30 2007, 03:02PM
Andrew L. Registered Member #515 Joined: Sun Feb 11 2007, 02:06PM
Wouldn't it start to boil in vacuum?
Experimentonomen
Sun Sept 30 2007, 04:05PM
Yes, and then freeze to ice.
Tesladownunder
Sun Sept 30 2007, 05:39PM
This is my HV and water topic from my site. The most interesting stuff is with deionised water which is non-conductive so charge will be held and not leak away. You can make interesting columns of non-flowing water.
I haven't tried the water bridge stuff though. I was in the process of cleaning a titanium electrode to put in the water which will be less likely to ionise than say copper. De-ionised water becomes conductive after a minute or so in use.
TDU
Electroholic
Sun Sept 30 2007, 08:17PM
wouldn't Pt / graphite be more suitable as inert electrodes?
Bored Chemist
Mon Oct 01 2007, 05:46AM
Even deionised water conducts slightly.
Tesladownunder
Wed Oct 03 2007, 02:29PM
I replicated the experiment with deionised water, two drinking glasses and my MOT multiplier that goes to about 9kV. Ruler has 1mm gradations.
TDU
1191421755 10 FT32063 Hvwaterbridge
ragnar
Wed Oct 03 2007, 03:00PM
Beautiful photograph, Peter! I like it how you can observe the different anode/cathode shapes that form at each end as well.
