  • Guests: 51
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Cinquecento disaster..
Wed Sept 26 2007, 07:40AM Print
Hi all.
I took this pice of junk to the garage for an overheating problem. They changed the radiator, thermostat, etc and flushed the system.
Went to drive it to town last night, and something mechanical gave way in the gearbox, giving symptoms of a stretched clutch cable.
So I checked. The lever is moving just fine but it won't go into gear and/or jumps out of gear. Reverse does not work AT ALL! (grindy crunch grind)
any ideas? i had to "limp" it all the way to the bridge in third gear, using the ignition key as a sort of clutch. (Bad idea I know) especially with all those damned FRICKING ROADWORKS GRRRRRRRRRRRRR frown
-A
(For sale. 1999 Fiat Cinq, needs minor attention, £500 ono)
Wed Sept 26 2007, 10:14AM
It's probably your clutch like you said.
thedatastream
Wed Sept 26 2007, 02:15PM
Fiat = Fix It Another Time wink
Fri Oct 12 2007, 09:10PM
New clutch did the trick. First gear is still a bit "grunchy" but hopefully that is just cosmetic. (exhaust related?) seems to go away when warm.
-A
