  • Guests: 59
Will these MMC caps work?
Jrz126
Sat Mar 04 2006, 10:34PM Print
I found these caps at Electronics Goldmine. Will they work?
the link
Also, for my series strings, how much further should I go over the rated voltage? My NST is running at 15kV (30mA) and 9 in series will give me 16.2kV, is that high enough?
Thanks,
Jeff
Marko
Sat Mar 04 2006, 10:38PM
No way.
Use at least 30kV mmc or higher with equalizer resistors, 5-10nF is most often used for 30mA nst.
And did you mean to put a link, add file or what..?
EEYORE
Sat Mar 04 2006, 11:10PM
Jrz126 wrote ...
Thanks,
Jeff
As far as capacitor type, i havent seen any suitable for an MMC from electronic goldmine.
Matt
Jrz126
Sun Mar 05 2006, 04:43PM
ok, link is fixed...so those caps are out?...Where might I find some suitable caps?
Would these work?
15kv
30kv
The guy said he's sold them to other people before for TC use.
Sun Mar 05 2006, 06:30PM
For safety, the voltage per string has to be: 15 kV * sqrt(2) * 2 = 42.3 kV. You can take a safety value = 2* 15 kV if dont have enough caps.
5600 pF are too small. For a 30 kV string you will have approx 17 cap per string, that means only 329 pF. You need a lot of caps to have enough primary capacitance.
The 15 kV and 30 kV caps seems to be used in the multipliers. I dont trust them in tesla coil service.
teravolt
Mon Mar 06 2006, 02:41AM
the kind capasitors that might work are mika, doornob, mylar type, or pulse type capasitors. Stay away from dc filter capasitors. An easy way to make a capasitors is to take beer bottles cover the out side with aluiminuim foil and put salt water on the inside with a stainless 1/8" to 1/4" rod suspended by a wine corck or rubber stopper. Ebay is a good place to look, or your loacal electronics surplus store for comeersial capasitors.
Hazmatt_(The Underdog)
Mon Mar 06 2006, 05:03AM
Okay, let me first say something about Mica Capacitors. They were Not designed for Tesla applications. They do not handle the pulse well at all.
What you're looking at are 2 very different capacitors. On the left is a Sprague vintage 4000pF 30KVDC doorknob, and on the right is a modern Ceramic Laser pulse capacitor.
I have used the Mica 'In-test' with my Allanson 12KVAC 30mA transformer and they stored and discharged what appeared to be okay. But!! when you use them to the extent you may envision, like my 720VA TC, THEY SHORT! One of my 12 spragues I know is shorted!
Not only that, but these capacitors were designed SOLELY for decoupling NOT pulse. The itty-bitty hardware studs are very evident of this!
These caps are also notorious for changing value because they are not constructed of a uniform dielectric. This is bad, very bad. The stresses you place on a nonuniform dielectric cause it sresses which will later cause a short or failure.
On the other hand, the 2000pF uniform ceramic doorknob capacitors are designed for stress, pulse, quick discharge, and have very heavy terminals. They are being used in my system with great performance. The only drawback is that you must have two plates supporting them that can carry the current. I have had no problems with using circuitboard as the plates other then 2 very important issues.
1. The plate have No corners. No corners prevents charge from intensifying at the points. This prevents massive breakouts. I had to redesign my plates when this became clear.
2. Margins and arcovers must be prevented. My margin on both plates is 1.5" and one plate is corona doped. This has eliminated all arcover issues.
1141621384 135 FT3150 Caps
