  • Guests: 35
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
Induction heater whith tubes
Experimentonomen
Thu Sept 13 2007, 06:21AM Print
Yesterday my 304TL arrived, and after a test i confirmed that it survived shipping so i started building up a prototype on a piece of chipboard, and sheet copper for everything conductive to reduce stray inductance.
I´ll take some pics later when i have bought new batteries to the camera.
Fri Sept 14 2007, 07:54AM
Sounds like fun hope to see some more soon. I've never seen a tube based induction heater. What operating frequency are you going to use?
Experimentonomen
Fri Sept 14 2007, 08:55AM
These are usually in the range of MHz.
Experimentonomen
Sat Sept 15 2007, 11:39AM
Here are some pics and a vid of the thing: Link2
Marko
Sat Sept 15 2007, 12:02PM
Hey, congrats man. What circuit are you using? I see you have that fat air-cored coil on it.
Regarding copper sheet conductors, it may be an overkill for the tube connections since current is low there, but looks nice and helps to dissipate heat ;)
Can you give us some higher-resolution pics? And schematic of course?
Tubes are nice for induction heaters because they can happily operate well in MHz range, and if your caps are good enough you can heat even 'stubborn' metals like aluminium and brass.
Experimentonomen
Sat Sept 15 2007, 01:53PM
I did that to reduce stray inductance, whick u get with the thin round wire that would be enuf to cary this current.
Link2 <-- i use that schemo, but the MOT feeds direct AC, and work coil is not 1.4" tubing and fb coil is 28 gauge wire, about 30 turns on a shithouse spool.
The dc block and tank cap are four 680pF russian doorknobs in parallel each.
