  • Guests: 52
Experiment movie
Sat Mar 04 2006, 07:07AM Print
I made a few days ago an energy transmission experiment for one of my friends, with the miniDRSSTC. The input voltage is cranked up slowly to 312 VDC, with a very low freq pulse (bolt lightning appearence). Here is the movie:
http://d.turboupload.com/d/403591/AVSEQ13.MPG.html
Enjoy
Marko
Sat Mar 04 2006, 12:21PM
Your movie doesnt work, wmp asks codec and if I try to convert it it throws out error messages.
Plasmaniac
Sat Mar 04 2006, 01:22PM
Plasmaniac Registered Member #206 Joined: Sat Feb 18 2006, 03:17PM
Do you have DivX?
Marko
Sat Mar 04 2006, 01:34PM
yes, it can't run the movie.
EDIT: it seems to be mpeg animation but with some error, wmp should run it with no problems.
radvideo should have turned that to AVI with no problems if it was OK...?
Sat Mar 04 2006, 02:01PM
I have DIVx and it runs the movie just fine.
Sat Mar 04 2006, 02:24PM
I have problems with codecs too.
Try this:
http://www.free-codecs.com/download/Codec_Pack_All_in_1.htm
I can make AVI too, but I like MPEG because the higher def.
Bjørn
Sat Mar 04 2006, 02:41PM
It is MPEG1 but VirtualDub says there are errors in it. Maybe faulty encoding or a file transfer error.
VLC media player will ignore the errors and just display some flickering on the broken parts: http://www.videolan.org/
The download was very slow for me so I mirrored the file: http://www.sciencezero.org/vasil/AVSEQ13.MPG
Marko
Sat Mar 04 2006, 06:10PM
I watched the film, I think lighting neons near coil is pretty common actually.
Well, and i also did some interesting experiments recently.
Small 1W bulb and lamp from saver bulb are energized perpetually.
This ''receiver'' is actually secondary of mini TC used as resonator, that is actually not resonant at all (frequency is about 1,5mhz) and it is picking power from 2Mhz micro SSTC (you've probably seen it) 1 meter away.
That SSTC actually lights neon bulbs in hand maybe 7-8cm away max, so this is very interesting.
Non-resonant secondary makes almost the same amount of power to be transmitted to 14 times larger distance.
Im confused about how it really helps here,
Neon is connected to ground wire of ''receiver'' and small 3V bulb is using 7 turns wound around secondary to couple with it magnetically.
If my hand or any grounded object approaches it dims the bulb.
Even more interesting is that neither coil nor ''receiver'' is not grounded, actually it suffocates the transfer if I ground them.
If we call it tesla's wireless energy transfer we may, but with such losses charging a cell phone would take long.
It rather shows principle than having some use.
I dont know exact efficiency but its obivously very small, im putting about 40 watts in coil, say half is dissipated (it dissipates a lot of heat on mosfets and secndary, EM loses, etc) so say 20 W is electric field, and I pick up maybe 2W from that. so say its not above 10%.
So much of that, maybe im running of the topic...
1141495808 89 FT3094 P1010035
Sat Mar 04 2006, 06:25PM
Nice pic Firkragg.
The movie is pretty commune, but was the single movie I made with this ocassion.
....and i like put them on forum.
It is quite nothing too special, just a neon and some sparks smile .
