  • Guests: 39
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
Michael W. (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
"Carbon" New Drsstc
Reaching
Wed Aug 15 2007, 07:27PM Print
Now, that i have more time, i wanted to build a new, big drsstc.
First attempt was to build a powerful discrete brick driver to power the fuji 1mbi400-06 (600A/800APulsed 600V).
That seemed not to be easy, cause the gate capacitance of one device is 84nF.
I wanted the input signal optocoupled so that i dont need a gdt or other driver transformers in the drsstc.
heres what i came up with by now
Carbon1
Heres the whole highside driver for the fullbridge. the power part such as the optocouplers are fully shielded to prevent any em interference. Powered by 2 print transformers i can drive 4 of the big fuji igbts up to 100khz cw! without big problems
Carbon4
Closeup of the 4 identical push pull drivers, nearly the same as a discrete ucc driver ic, but much more powerful, much more forgiving.
Sigout100khz
Heres the output signal of one stage without igbt connected. div5v/cm 5µS/cm 100khz
Sigout100khzmitlast
heres the gate signal of one of these heavy igbts with 84nf gate capacitance, at 100khz cw!
For sure, the signal is not bad but not nice. i plan to get a resonant frequency of around 50khz or so, so the gate waveforms should look much better at half the frequency.
So give it a go. More to come soon. No Specs for the secondary, mmc yet
Experimentonomen
Wed Aug 15 2007, 07:36PM
Niiiiiiice start :)
Marko
Wed Aug 15 2007, 08:02PM
Hate to say it now, but I would be very wary of those dual-secondary transformers. Insulation between those two windings is usually very poor, but fact that brick is 600V probably saves the day.
Reaching
Wed Aug 15 2007, 08:04PM
They dont look like, but they are 4kV tested in insulation, and cost about 4 times as much as a normal print transformer. they should stand up the few hundred volts
Firnagzen
Thu Aug 16 2007, 07:56AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
Good grief. You built 2 H-bridges to drive a H-bridge? I really admire the work you've put into this, I don't think I'd have the patience!
Reaching
Thu Aug 16 2007, 11:51AM
Okay, i made some decisions about the size and wire gauge of the secondary coil and came up with 2 designs. Now i wanted to know, cause its the first time i build such a huge secondary and i dont want to waste my money and time, what data is significant, especially for a huge drsstc secondary
Heres the first design
Secondary diameter 16cm ~6,2"
Winding lenght 90cm ~ 35,4"
Wire gauge 0,4mm~ 26awg
turns 2249
toroid 15x60cm~26,4pf
resonant frequncy 68,7khz
dc resistance 155ohms
Q 309
Heres the second design
Secondary diameter 20cm~ 7,87"
Winding lenght 100cm~39,37"
Wire gauge 0,5mm~ 24awg
turns 2000
resonant frequncy 63,8khz
dc resistance 110ohms
Q 428
and not to come to wrong conclusions here. its not 2 H bridges. the driver consists of 4 pus pull arrangements to drive each for itself one brick of a H bridge
For any of you who might want to know exactly how it works, heres the shematic of one driver. Link2
The whole design was simulated by sw cad and build up several times. i even build the whole thing to determine the maximum, minimum frequency range, frequncy range of the optocoupler and so on
yeah, and for those who are familar with optocouplers or high side drivers in general. the delay between input and output is 1,6µS. thats a lot, but i think i should give it a go, cause every input signal is delayed by 1,6µS. The optocoupler itself delays the signal 1,4µS.. maybe it will grow to a problem with overcurrent protection, cause the bridge turns off 1,6µS after the ocd was detected. but dont know.
Thu Aug 16 2007, 06:01PM
That is a seriously huge delay. Dont worry about the OCD, it shuts off at a normal switching event. But, you will be hard switching big time, all the time. Transformers dont look so bad compared to those slooooooow opto-isolators (my signal transformers only add a few nS delay). Id suggest you look into newer opto's, you can get some with only 60nS delay times.
Lets take a look at how bad the switching will be with that delay time. 50khz has a half-period of 10uS. At 16% of that period, you will be switching sin(180*.16) = 48% of the peak current! Thats really quite bad since large DRSSTCs need at least 1kA for decent results (so hard switched 500A). This makes dealing with voltage spikes nearly impossible and also lowers your power-factor a good bit (so lower efficiency accordingly).
Fix those optocouplers! Im also not convinced the rest of that gate driver (with the discrete transistor buffer) is all that fast either. I tried hard to get my total propagation delay (from CT feedback input, to gate driver output) down to something like 150nS (less than 1/10th of just your optocoupler). Even switching from 15V to 5V logic (since its faster) made a very noticable difference in switching noise.
I suppose it probably would work to some extent, but i personally would not use it.
Reaching
Thu Aug 16 2007, 06:56PM
the Delaytime is not within the bridge itself steve. the complete bridge is delayed 1,6µS. so just every igbt within the bridge has the same delaytime and that means no hard switching for 1,6µs. the delay is just between the input signal (Oprocoupler) and the output signal. so i drive the gate driver with say a 100khz signal, there is 1,6µs delay between the input 100khz and the output 100khz.
i tested the bridge as it is (loose wiring) at 50khz from a signal generator on cw with an bridge input voltage of 100V. The current draw of the bridge without load was around 100mA which is quite good.
No Delay between each igbt, so for safety i should add a bit deadtime
Thu Aug 16 2007, 06:57PM
I haven't used 4N26, but I have used 4N25 which is similar.
Have a look at these application notes Link2 and Link2
to see how a major speed improvement can be made with minimal changes.
Also, what's the purpose of R4,R5,R6,R7 compared to removing all four and
connecting both bases of Q2 and Q3 to the collector of Q1?
i.e. a little speed lost here.
Reducing R2 and R3 to 1 kOhm would also make it a lot faster
the resistors would dissipate 400mW and 200mW respectively, not much for the speed gain.
Thu Aug 16 2007, 07:22PM
Well, big IGBTs can have turn-off delays of almost 1us themselves, if not more for those old Fuji Electric monsters. So you can increase that 48% to 100% :P This is why I got so interested in PLLs. They can dial in a phase lead to compensate all the delays in your circuit. (it takes a cycle or two for the loop to settle though, so don't worry, no time travel needed...)
The Toshiba TLP250 is a fast optocoupled gate driver that comes to mind.
